Question about Fisher and Paykel GWL11 Top Load Washer
Tub out of balance
Tub sits out of balance even without clothes in it.
  • 125 Answers
Assuming the machine is level I would first push the wash basket to the right rear corner while holding it there look to see if the spring on the left front corner is connected, if not reconnect it if its gone order a new one. Hope this helps
Posted on Jan 12, 2008
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
The tub of my toploading washing machine leans to the front right, It is balanced and leans whether clothes or in it or not. I can spin clothes if I prop lid open and hold tub straight .
The suspension springs have gone out of alignment or the tub holding mechanism is shifted. look throught the bottom to see the fault in the suspension. correct on the mountings.
Even a leaning can come if the motor suspension is out of alignment.This must be centered in and the top door will close evenly.
Sep 01, 2010 | Kenmore Washing Machines
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Admiral washer
Guess you need to change the ,it links motor to the transmission.
OR
There aren't enough clothes in the machine to keep the tub balanced. Wash bigger loads or lift the lid when the banging starts and re-space the clothes evenly around the tub .
Thanks for contacting fixya.com
Nov 10, 2009 | Washing Machines
Drum out of balance after repair on 20722 kenmore washer
THESE WASHERS SIT ON A SKATE PLATE PICK UP ON THE TUB A TURN IT A BIT AND TRY IT ONCE IT IS BACK ON THE SKATE PLATE WILL OPERATE PROPERLY
Apr 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer tub seems to be continually out of balance
You may have to turn your washing machine upside down and check the balance bolts and springs, to make sure that they are snug or secure.
Jan 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
DRUM OUT OFF BALANCE IN HI SPEED /ENTY OR FULL
CHECK TO SEE IF A TUB SPRING IS OFF,SOME WASHER TUB SIT IN A V,PULL UP AND TURN TO SEE IF YOU CAN GET IT BACK IN THE V,ALSO MAKE SURE LEVEL AND YOUR CLOTHS ARE EVEN IN THE TUB,THANKS-MIKE
May 29, 2008 | Maytag Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
96 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
