Question about Samsung PS42P2S 42 in. Plasma Television
Two grey 3in lines at either side of screen
Is there any way to get rid of them also my panel is locked and have no remote control for tv
  • Samsung Master
  • 5,138 Answers
Yes take set to repair shop this is not a fix it yourself problem!
Posted on Feb 08, 2008
Grey vertical line at the bottom of tv screen. 50" Hisense smart tv
The TCON board or the LCD panel is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
May 26, 2016 | Hisense Televison & Video
How do I get rid of grey borders on sides of screen?
Grey border comes on the screen may be because or the LCD panel is faulty or the t cone baord is bad. as you didnt mentioed anything about the brand and model number its not possible an exact solution. Here added link with the help which you will be able to solve the issue .
Nov 06, 2015 | Televison & Video
How do i get rid of the blue box on my tv screen without a remote? Its from the picture inside the picture.
Normally there are controls for tv on rear to 1 side of tv , different sides for different makes, LG is on right hand side when looking at the screen.
Nov 29, 2014 | Televison & Video
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
This is more likely a loose connection. You would need to remove the TV stand, back panel. Remove the front cover and panel. Where the TV stand sits on the front of the TV there is a cover you need to remove. It's easy there is a metal frame all around the front panel, at the base is the what you need to get to. There are 2 white computer cables, one controls the left side, the other the right side of the LED's. When this cable comes loose, you have the problem you described. to remove the cable lift up on the small black bar just above where the cable connects.
Mar 21, 2013 | Sharp LC60LE810UN 60 in. LCD TV
Grey strip on each side of TV screen that blocks picture
Try to check the input of your TV. Check the aspect ratio of your TV by using your remote control
Sep 09, 2011 | LG 42LC2D 42 in. LCD HDTV
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a grey band on my tv showing which input select is on. e.g. av2 - how do I get rid of it?
Press Info/ Display button on TV remote, on-screen display (gray band info) will disappear.
Dec 19, 2009 | Sony BRAVIA KDL52XBR2 Television
How To Remove A Parental Lock Without The Remote Control?
we have parental lock on our tv.....the screen is blue with a lock in the lower left corner,we can't get it of with our 3in 1 remote....a tv. repair man said we needed the original remote....can you help with this problem
Jun 02, 2008 | Durabrand DWT1905 TV
Samsung PS42P2S 42 in. Plasma Television Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
