Remove the glass turntable, then the roller ring. Then seta glas of water in the unit and turn it on for 5 to 10 seconds. Look through the door window and see if the drive hub is rotating. If it is, then check the underside of the glass table to match up the drive hub. If it isn't turming, the drive, then it is internal and should have a 1 yr warrantee minimum. Remember, the, the turntable and drive must engage each other and the roller ring in place. Good Luck, and let me know please. One more thing, make sure there isn't a Turntable on/off swirch set in the off position. Good Luck, Ne
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic NN-H504WF 1200 Watts
the microwave turn on ok fan works but not heating food all buttons work but there's a heat blinking...
(More)
the microwave turn on ok fan works but not heating food all buttons work but there's a heat blinking indicator not lit up on display
I have a Panasonic Genius 1200W which still has power to the front panel, but when you try to cook...
(More)
I have a Panasonic Genius 1200W which still has power to the front panel, but when you try to cook something, it appears to operate but cuts out after three seconds and does not heat anything during that time. Thnaks
the microwave continues with light on and turntable turning despite the time running out and...
(More)
the microwave continues with light on and turntable turning despite the time running out and pressing reset etc.
