Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Wep210 headset how do i keep it on my ear
  • 3 Answers
The earpiece comes prefitted with a rubber ring that isn't very good.
You need to pull this off and replace it with the loop rubber earpiece that should of been supplied with it. This is much better and will hold it in the ear. Position it depending on whether you want to wear it in your left or right ear.
Posted on Jan 23, 2008
Needs to have the earpiece redsigned like the headphones provided for the radio on g600 model can i swap my we200 for a redisigned one like that please
Posted on Dec 27, 2007
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
Jan 28, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG MOBILE CANT LOCATE THIS HANDSET
I have bluetooth samsung 210 and I just bought it todaty , ,my mobile does nit see it
Jan 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG BLUETOOTH WEP210 NEED TO KNOW HOW TO PAIR TO PHONE
Your manual can be found here... it should walk you through the connection process fairly easily.
Mar 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I AM LOOKING FOR BLUETOOTH REPLACEMENT PARTS
go to hellodirect.com Order item number 28935. (Put this into the item search and make sure it is the correct thing) cost of a 5 pack is $6.99 + $2.00 postage.
Jan 30, 2009 | Jabra Bluetooth Headset with Adjustable...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Can't conect headset
you need to hold down the button on your headset until the blue stays on instead of flashing, then the headset has been reset, then try pairing your phone with your headset, and type in 0000 as the password, this should solve your problem :)
Sep 07, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth code
Usually with headsets code 0000 works by default.
Aug 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
137 people viewed this question
Top Samsung Radio Communications Experts
ivan georgiev
ivan georgiev
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
