Infinity BASSLINK Car Subwoofer
Problem for Infinity BASSLINK Car Subwoofer
My sub woofer wont turn back on
By austin_opitz on Oct 14, 2009
I have an Infinity Basslink subwoofer in my 2002 accord hooked up to speaker level input. It has been in there for nine months and I have had no problems with it. Just the other day, though, I was towards the end of a 2 hour road trip when my sub just turned off and will not power back on. When i jumper the Battery terminal on the back of the amp to the REM terminal, the sub powers up and sounds like normal. I called Crutchfield support and they determined that the auto-turn on was not working so they had me send it back and they sent me a replacement. I am having the exact same problem with the replacement so i assume the problem must be in my car.
Solution #1
posted on Oct 17, 2009
Not Rated)
etirbynnor
Rank: Guru  Car Audio & Electronics  Expert
Rating: 94%, 263 votes
Hello austin_optiz,
If you have had 2 units with the same problem, I'd say that yes, there is a problem with the "sound sensing" function of the auto turn-on circuit. Either it's not getting the correct level or one side is being shorted or grounded. Some vehicle speakers may have one side at ground potential which could cause the auto turn-on to fail.
If the Basslink operates normally otherwise, I'd recommend that you just connect a 12V + fused and switched source to the remote terminal. Wire it through a conveniently mounted toggle switch and turn it on and off manually.
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Infinity BASSLINK Car
Questions and Unsolved Problems for Infinity BASSLINK Car
Do you recommend Infinity BASSLINK Car Subwoofer?
Answer
Answer
i need the plug for the four line speaker input for basslink infinity
Answer
I have a infinity Basslink and the remote volume knob isnt functioning anymore. it uses a RJ-11... (More)
Answer
all speakers play except the sub. the controls for the fader and balance dont work on the dashboard.... (More)
Answer
I have a '99 bmw 3 series with the business cassette radio/6 disk changer. Installed a basslink... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Infinity BASSLINK Car...:
Top Car Speaker and Sub... Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Speaker and Sub... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
