Question about Tomtom ONE GPS Receiver
Big X on tomtom screen..and not functioning.
When doing a backup and synchronization, my tomtom, got screwed up. Now when I power it up, i just get the stupid tomtom sound, and a big X on the screen. I Tried to download latest update, and get a failure. Right now, it is just a door stop...what a waste. I would have left it alone, but my laptop kept getting a message to upgrade software, which i thought was a new release of the embedded tomtom software, and turned out to be a new release of tomtom home.
  • Anonymous Apr 29, 2009
    tomtom screen doesn't work
    tomtom customer help useless,
    tomtom website just sends you round in circles.
    I suspect a con to avoid refund for a poor product
  • 515 Answers
How to backup tomtom
Back to support home page The easiest way to make a backup of all the contents of your TomTom device is by using TomTom HOME. You can make one backup per device and store it on your computer. When you make a new backup, the old backup for that device is overwritten.
Tip: We recommend setting HOME to back up automatically before installing new content. [ more... ]
  1. Connect your navigation device to your computer and switch it on.
    TomTom HOME starts automatically.
    If TomTom HOME does not start, do one of the following:
    • Windows 8:
      Right-click on the Start screen and click All apps. Then scroll through the list of applications until you see TomTom HOME. Double click to open the program.
    • Older versions of Windows:
      Click Start > All Programs > TomTom > TomTom HOME.
    • Mac:
      Click Go in the Finder menu and choose Applications, then double-click TomTom HOME.
    Click Back up and restore in the HOME menu.
  2. Click Back up my device and then click Back up now in the bottom right corner.
    HOME backs up your device.
  3. Wait until HOME has finished creating the backup.
    Then click Done.
To see where HOME saves your backups do one of the following:
  • Windows: Click Tools > TomTom HOME Preferences and then select the Folder Preferences tab.
  • Mac: Click TomTom HOME > Preferences... and then select the Folder Preferences tab.
To restore a backup, click Back up and restore in the HOME menu and then click Restore my device.
Dec 09, 2013 | Tomtom One Europe v2 GPS Receiver
My TomTom one xl is showing a big red X on the opening screen . and cant do and thing else.
If you have a big red circle with a white X in it, indicates that you have a serious problem with your unit:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) If above does not work, connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
3) If above does not work, and this is usually the solution for 'big X error', use TomTom Home to restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom GPS
My tomtom is connecting fine to the computer, but once I get the pop up window saying my device is safe to properly disconnect and I disconnect it and try to turn it on without it being hooked up to the...
If you have a big red circle with a white X in it, it usually means that your TomTom One 'disk' is corrupted: first try a 'hard reset' , while the power is on, stick a small (tooth) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressur on the stick will cause a complete system reboot if possible.
Next, since you can connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
If there is an error or you cannot reboot, hopefully you have a backup made either by copying the whole unit disk content or more traditionally via TomTom Home, I would suggest a complete restore your device content follow by a TomTom Home device update.
Hope it helps: let me know how you go.
Jan 05, 2010 | Tomtom ONE XL GPS
It shows a 'X' mark
the other users who faced the same error tried this instructions and solved the problem as follows:-- We have a result!
After calling the helpline to find it was number unobtainable! I returned the unit to Halfords who called another helpline number. They took my e-mail address and when I returned home an e-mail was waiting with the following instructions which worked.
I now have a fully functioning TomTom! Thanks for the advice fellas:
Thank you for contacting TomTom Customer Support.
In this email you will find the solution for the error on your TomTom. This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Nov 03, 2009 | Tomtom GO 720 GPS Receiver
!!!!! HELP !!!! BIG RED CROSS WHEN ENTER SD CARD
Hi there
This happens because files on your card are corrupted after an unsuccessful download.
If you have a card backup at hand, put the card into a computer, format it , and restore backup.
After that the TOMTOM will restart working normally.
If you did not make a copy or backup of the original card, or you cannot reach the computer hosting the last backup.Then follow the procedure below to restore your data :
1. Uninstall the application
2. Reinstall the application
attention_25.gif We highly recommend backing up your device before continuing. questionmark_25.gif
This will preserve any maps and voices you may have purchased.
1. Connect your device to your computer.
2. Go to Computer (Vista), My Computer (XP) or your Desktop (Mac).
3. Double-click the TomTom disk drive to open your TomTom.
4. Make sure that hidden folders and files are shown. To do this:
  • Vista: Go to Organize > Folder and Search Options, click on the View tab and select the option Show hidden files and folders.
  • XP: Tools > Folder Options..., click on the View tab and select the option Show hidden files and folders.
  • Mac: With the exception of some system files, your Mac should already show all hidden files and folders on the TomTom drive.
5. Identify the map folders on the TomTom. These are named for countries or regions such as USA_and_Canada, North_America or any other country or geographical region.
6. Delete all files EXCEPT these map folder(s) and the folder titled ASR, if it exists (the ASR folder will not appear on every device).
7. Properly disconnect the TomTom from the computer and exit TomTom HOME, if it is open.
  • Vista/XP: Right-click the TomTom drive and choose Eject.
  • Mac: Drag the TomTom drive to your Trash.
8. When the TomTom boots you should see a screen with the flashing X.
Proceed to reinstall the application (below):
Apr 26, 2009 | Tomtom GO 300 GPS Receiver
My 720 frozen
• The device hangs in the start screen (splash screen )
Nov 19, 2008 | Tomtom GO 720 GPS Receiver
Tomtom ONE 3RD EDITION
I have seen this before on my TomTom as well.
Do you have a backup save? The was I fixed this was to plug a 1Gig SD card into a card reader (not the TomTom) and copy the backup file directly to the card and then plug in into the TomTom while turned off and then powered it on.
if you do have a backup, you should be able to find it under you My Documents folder under the TomTom folder.
Mar 29, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
TOMTOM ONE frozen
You all have a problem with the operating system of your tom toms. Call tech support at 866-486-6866.
Nov 24, 2007 | Tomtom ONE GPS Receiver
Treo 650 Hotsync Problem
Many factors can influence the synchronization process. you will have to go step by step from this: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(25004) Good luck.
Jan 04, 2006 | Palm Treo 650 Handheld
Tomtom ONE GPS Receiver Logo
445 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
