Question about Onkyo TX-DS777
Synchronisation problems I have recent bought a Samsung Plasma panel (PS-42Q96HD) and i have Samsung terrestial (P850) receiver wich is connected with S-video through the receiver so both the picture and audio comes from the receiver, however the sound gets a little bit ahead of the picture and i cant find anywhere to get it adjusted properly. I have tried with a S-video cable directly from the terrestial receiver but without success.
  • Ackemini Dec 28, 2007
    This wont work, i have tried several differens settings and differenscables without sucess, the DVD suffers with the same problem,
  • loud 1 Mar 02, 2008
    Samsung 50 inch plasma - running sound via phono outlets to a Denon receiver - picture is a few hundred millisec behind sound. Ok on DVD because receiver has facility to delay a digital input, but not the analog input from the TV output.
    TV own speakers are ok so why is the phono output out of sync ?
    Taking sound from Sky box phono direct to Denon is also out of sync.
    TV also has an optical output which may be a solution, but I am already using all the optical inputs on the Denon for other functions.
    Peter
    Problem Solver:
  • 72 Answers
Try to change the sound setting of your reciever.. try all options of sound setting..
Posted on Dec 27, 2007
Ps 42q96hd
The digital part? Do you mean you have sound but no picture/video? Does the power LED on the front of the TV flash? Just about every board in the TV can cause this symptom. You may need a trained TV technician diagnose it further. If you need replacement boards, Tri-State Module is a good vendor for me.
Nov 04, 2013 | Samsung HP-R4262 42 in. Plasma Television
Samsung PS-42Q96HD
Please check whether the inverter is working and giving voltage to the display board. If not, this might require attention of a qualified service technician.
Jul 12, 2012 | Televison & Video
Samsung 42q96hd shuts down starts again
Look or have someone look at the power supply first in this set for this problem, it could be elsewhere but the supply needs to be checked out first.
May 24, 2012 | Samsung PS50Q97HDX 50 in. Plasma TV
My pioneer plasma tv is pdp-r04u with media receiver. The back of the receiver has a s-video jack "monitor out". what shoud i connect it to?
My initial response is "An S-Video Cable"... but I suspect this isn't the information you are seeking.
You don't need to connect your receiver to the TV's video inputs UNLESS you want the receiver to switch between different video devices.
PS - more information on what "my receiver" is would help too, also tell us what you're trying to accomplish as the end result.
tell us about all the equipment you have, and how you would ultimately like to be able to control everything, and what inputs and outputs are on each device.
Feb 22, 2011 | Pioneer Televison & Video
Having problems getting a full picture on my PS-42Q96HD
i have seen this before and it is the logic board failing
Dec 03, 2009 | Samsung HP-R4262 42 in. Plasma Television
Connecting my HP Pavillion DV9500 laptop to my Samsung PS-42Q96HD
Sound more like your problem is with the connection to the TV. Make sure the connection at the TV is to an 'input' connector and not 'output'. Also, from the TV menu, if you can select the output the laptop is using make sure the sound is stereo an not 5.1 or 7.1 or something to that effect. All other connections seem to be in good shape. Good luck.
Feb 03, 2009 | Humminbird Computers & Internet
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Samsung PS-42S5H
Since you smell it above one side of the panel I will guess the right side (from the front). This is where the Y Sustain board is located, it has large heatsinks over the drive ic's to dissapate heat. If the ic's are bad this is more than likely the smell. This board controls the scan of the picture and drives the plasma panel. I would definatly have a technician look at the unit, these are normaly econimical to repair.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
Sep 17, 2007 | Televison & Video
Onkyo TX-DS777 Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
