Question about Nintendo DS Lite Console
Wing buttons won't work
My son says the system was dropped by little sister and the right wing button will not work. We were playing Tetris the other day and he was excited that it did work some but nothing you can count on. I hate to buy a whole new system for this reason, can you offer any solutions? I went to the nintendo web site but they don't have this problem listed anywhere.
    Problem Solver:
  • 13 Answers
Your best option is to call 1-800-255-3700 and ask for technical support they might need you to send in the unit for repairs.
Posted on Dec 27, 2007
Cant hear my radio
The radio system on the Goldwing is equipped with a "Mute" button. More often than not, the issues are from this button not releasing completely on the inside of the switch. I suggest playing with the mute switch. Work it "on" and "off" over and over.
Mar 24, 2014 | 1984 Honda GL 1200 Aspencade Gold Wing
Left wing won't open
Maybe you have to press the round red button under the word LIGHTYEAR. That would make left wing open.
Nov 28, 2013 | Thinkway Toy Story Buzz Lightyear Space...
My wing work fine when its on but it is hard to turn on i allway have to play with the button but now it just stop workin for me
spray some WD40 onto the affected button, and make sure the battery is removed and phone is OFF. After u spray WD40, push the button gently until the sprayed solution evaporates. Good luck.
Jan 05, 2011 | T-Mobile Wing™ Smartphone
My wing t-mobile display was locked. And what
You need to do a hard-reset. This will erase your added content (third party programs stored in phone memory, notes store in phone memory, etc.)
You must press the reset button while pressing the left and right soft-buttons at the same time. You need your stylus or something small enough to press the recessed button next to the volume control. Once you press the reset button, keep holding the soft buttons it is reset. The display lock should be gone... as well as everything else you put on it.
Hope this helps,
Mar 27, 2010 | T-Mobile Wing™ Smartphone
Guide about lugia's ocean adventure
you halft to have or get the silver wing. which i forget how to get so your going to hlft to ask someone else. so after you have the silver wing a door thats not there unless you have the silver wing! and then just make you way through the maze of rocks and walls. and oh ya dont make the same mistake i did by going down there to capture lugia without either a master ball or about 100 ultra balls. good luck! !0.0!
Feb 26, 2009 | Pokemon Video Game Consoles & Games
My tmobile wing keeps freezing up when I try and text
It took me a long *** time to fix my wing, but this is the only way i found. shout out to my homie muhammed for showing me:
hold both left and right toggle button simultaneously, and use stick to press the reset button. continue to hold buttons....
it will reformat. press send to wipe the phone.
then, use active sync to completely wipe the micro sd memory card once wipe is complete
this will delete the static charge virus
lastly, go to tmobile website and download the rom software upgrade.
reconnect the wing to your pc
charge the phone past 50%
click on the new software upgrade icon and follow instructions.
the screen will show 3 lines, green red and blue with the new upgrade version numbers.
once complete, you have completely upgraded the tmobile wing to the fullest extent
if this does not work, then sadly enough.... your problem is from dropping your phone too many times and causing the components to become loose connections. aka the sliding keyboard.
i also noticed that the only thing stopping the keyboard from stopping is a tiny square piece of plastic. but then again, this phone was crafted in china. chinese plastic isn't the most sturdy composite material.
Dec 01, 2008 | T-Mobile Wing™ Smartphone
Slow Responses
Do a backup with PIM Backup and them hard reset the phone (Factory default)
To hard reset the wing: Hold both soft keys down while hitting the reset button with your stylus (the little hole on the side). Should bring up a black screen with some text. Press "send" key to finish process.
*Note it takes a couple of tries to get all of the buttons pressed together. May not work first try.
Aug 14, 2008 | T-Mobile Wing™ Smartphone
T mobile wing user code unlock i had the same problem you must do a hard reset it will wipe out all your data (phone nums etc...) but it will reset your phone to factory default. heres how:
1 there are two soft keys on the wing one is the button on top of the send call button the other is a button ontop of the end call button hold them both down at the same time.
2 there is a reset button on the left side of the wing (above the place the micro memory card goes) use your stylus or something to press the reset button for 1 or 2 sec then release the reset button while you are still pressing and holding the two soft keys
3 continue to hold the 2 soft keys the screen will turn black and a message will be displayed (giving you a warning that all your data is about to be erased do you want to cancel or accept the reset) you must choose accept and the phone wipe data back to factory settings and unlock all you have to do now is reprogram contacts and whatever other info you had in the phone
if you do this right you phone will be back to normal i promise e mail and let me know if you fixed it p.s. if you could help me find the wing unlock code if you know it and the procedure to unlock to another carrier please tell me
peace, TATUM
May 24, 2008 | T-Mobile Wing™ Smartphone
You can do a hardware reset of the phone. To do this hold the two soft keys in the front of the phone while depressing the reset button on the side. The rest button is located at the bottom of the volume level slider on the left hand side of the phone. You will need to stick a pen or something in there..The two soft keys are directly on the front of the phone right above the "ok" button and windows button.
It is very important that you do that all at the same time.. Release the "reset" button while still holding the two soft key buttons. After a couple seconds a black screen will appear telling you that it will erase everything..Just accept and that's it
Apr 26, 2008 | T-Mobile Wing™ Smartphone
T-mobile wing
Check your settings for sound, also turn it up with the rocker button on the side. Good luck
Feb 11, 2008 | T-Mobile Wing™ Smartphone
Nintendo DS Lite Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
