I want to add extra memory chip to my PCCHIPS P21G motherboard. Existing chip is a: DIMMO 1024Mb 2,793 Mhz. What will work? Was told that a PNY 1gb DDR PC 3200 will work. True?
Comments:
Oct 15, 2009
- Thank you everyone for your responses!! This is the second time I have used this site and now, due to these answers, I plan on joining as a full member. My first time using resulted in an insult response about how my beloved Chevy Tracker being a piece of junk. In fact, it is a very reliable ride pushing 200,000 miles of inexpensive 4x4, convertable fun!! This time I received very useful, professional advice!! Thanks, I'll be back! Dan
Yes you can add PNY 1GB DDR PC3200 400MHz DIMM to your system but your current memory may be running slower. You should match the memory you are currently running when performing a memory upgrade. Your MB can run: Two 184-pin 2.5V DIMM sockets for DDR SDRAM memory modules. Supports DDR400/333/266 memory bus. Maximum installed memory you can run is 2GB. So if the memory in your system is running at DDR PC2700 333MHz or DDR PC2100 266MHz & you add 1 GB of DDR PC3200 400MHz to your system. Your MB will lower the speed of the PC3200 400MHz down to match the speed of the possible slower memory currently in your system. Look at your current 1GB memory. It’s not possible for it to run at 2,793MHz. There should be a sticker on your current memory. It should show the manufacture name and its speed; PC2100, PC2700 or PC3200. Below is a link to PNY memory; http://www.newegg.com/Product/Product.aspx?Item=N82E16820236112&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Memory+(Desktop+Memory)-_-PNY+Technologies++Inc.-_-20236112 Hope you find this helpful. Cheers! Mike
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks Mike! You confirmed the info I received from the Geek Squad rep at best buy which differs from the info from a young geek working at staples.
" - dlaw2
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with...
(More)
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with 4 fans +pw supply fan. Will stay on only if i plug the mid pw connection to afan if i take off l.e.d.s lite up all fans will run then turn off after 7seconds . i also sence a burnt oder i think maybe i have a weak pw supply.
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this...
(More)
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this case came with 4 fans plus pw sply. is this too much for this bd . I smell alittle toasty but it all turns on ok if i connect a fith to the middle. not the cpu fan . ihave a 500 watt pw sply.i want to make sure the wires are connected right and that what i smell is just too much so i can disconnect and just get me a newer bd with instructions...thanks. if icould view a pit .would be great..
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
