Question about Yamaha RX-V661 Receiver
Surround sound this receiver is driving me nuts. Have done the auto program at least ten times. All speakers operate, yet when i try to get surround sound, the rear two speakers do not operate.
1. have you got a surround sound recorded media ?
2. what input are you inputting ? digital or analogue LR
3. is auto surround on or off in the setup.?
4. is your dvd player dts and dolby digital ready?
answer me the questions ... in the process you will solve your problems.
regards
david174@gmail.com
Posted on Jan 31, 2008
Rear speakers on vsx1122 not playing, they tested okay
Manually change your surround settings for your satellite box input. Your box may not be putting out a signal that the receiver auto-detects as a surround sound signal, thus it just plays in stereo.
Dec 26, 2012 | Pioneer VSX-1122-K Receiver
No matter what I do, I'm not getting any sound from my surround sound speakers, switched the wires around on the modual (swapped front and rear) and got sound out rears, so speakers are okay....I'm no...
Verify that all speakers are wired with the proper polarity and that they are making good contact, then verify that the speakers are receiving a signal with a multimeter, and check the impedance of the speaker as well to make sure they are not blown.
Mar 15, 2011 | Bose Acoustimass 6 III System
I'm going to surround sound mode, and my rear speakers are not working. I do a tone test, and they def work, but I can't get them working right?
Since you seem to be having problems with 'simulated' surround, how does ACTUAL surround material behave?
Have you tried AFD with certifiable multichannel source material to verify the surround speakers receive programmed sound??
Do the Dolby Digital or Pro Logic indicators light?
What about the other modes?
Mar 20, 2010 | Sony STR-DE475 Receiver
Is there any upgrade avaiable to allow the Dolby Digital EX to remain ON (not AUTO) after the unit it reset? Per page 78 of the manual, it resets to AUTO, so I have to manually go into the menu to enable...
Enter the sound menu. Under the selection for extended surround, choose "on."
Then, under type select "EX/ES."
The way it is currently set for you, the movie software has to have a "flag" that your receivers' decoder must recognize in order for your rear surround speakers to function for a particular movie. Not all movies in DTS-ES or DD-EX have this flag encoded in it's software. So the rear surround channels would not be commanded by the software to be decoded and played automatically...thus requiring you to enable them yourself.
Setting it to "on" in the sound menu will take care of that problem.
Dec 31, 2009 | Yamaha RX-V661 Receiver
Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Jul 04, 2009 | Jensen CS10 Speaker
Lost my sound in my surround speakers
Check your speaker setup onscreen ( monitor) viewed configuration, be sure you are enabling SURROUND SPEAKERS, or REAR SURROUND if you are running 7.1, then check the AUTO input to be sure you are receiving a MULTI-CHANNEL SIGNAL within the DIGITAL/ANALOG source. Cycle through the DSP Analog modes ie. Pro-Logic, Rock Concert etc. and check your DIGITAL signal indicator for a 5.1 DD or DTS input, if you hit a unitentional button then you will just need to reset it back to prior operation before loseing the surround speakers.
Feb 20, 2009 | Denon Audio Players & Recorders
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
Surround sound will not work sr805
Did the speaker cailibration work on the speakers in question?
If YES, then the program material or settings you're using don't require the rear speakers.
By "Back" do we mean Surround or Surround Back? Surround Back speakers are the 6th and 7th channels in the 7.1 matrix. Not all source material has programming for them. But when using any 7.1 digital surround mode you can get anything, even stereo recordings, to output something from every speaker.
If NO, check your connections...
http://63.148.251.135/redirect_service.cfm?type=QuickHookup&file=TXSR805_QSS_En_0330.pdf
Dec 21, 2008 | Onkyo TX-SR803 Receiver
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
Surround sound problems
Try changing your cables
Mar 11, 2007 | Yamaha HTR-5660 Receiver
Yamaha RX-V661 Receiver Logo
108 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
