I have Onkyo 605. Ran HDMI to tv from receiver - optical from blu ray to receiver and hdmi. NO video. SO I ran HDMI directly to tv from blu ray and optic to receiver. Now I get a picture but the back speakers do not work. I doesn't sound surround. The back speakers test ok but no sound with videos. How is best to hook up - blu ray(sony), receiver, and tv (plasma panasonic on hdmi input)? Thanks Shar
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
Hi, You have connected from PC to TV right??? 1.To get the video you have to connect to TV 2.Please take a separate cables for to listen audio and to watch video, for audio connect cables from DVD Player to Home Theater you can listen the audio for video please connect the HDMI video to TV Where You can enjoy both.
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals. The video from the BR player will have to go directly to an HDMI input of your hi def TV. In this case, either Sony or Panasonic BR player will be equal. Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo. In an ideal world, your receiver would some that does do HDMI switching. This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV. This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver. That said, buying a new receiver in addition to a BR player is more costly. Good luck. Let us know how it goes.
If your home theater has an hdmi in and out then you wuol be better of connecting the blu-ray hdmi to your home theater then to your tv. If all you have are optical connections to your reciever then what your doing will work fine. Additionally if your blu-ray has built in decoders not present in your reciever and also has 5.1 or 7.1 analog outs you can connect them to a six or seven channel in on your reciever if it is so equipped and have the benefit of true-hd or other current audio formats on current Blu-rays
run blue ray diret to tv ok or set it in 720 p mode with bit stream for sound but go diredct to tv and back from tv in coxial in of sterio ok for sound
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605. Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605. It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
