My toshiba D-VRW1SU DVD/VCR recorder combo
Went to bed and the unit was on.This morning it was shut off,just the clock on and showing the timer set.Went to turn it on by remote....nothing.Pressed the on button on unit....still nothing.Unplugged for half an hour...plugged in...clock still reading correct time,unit still wont turn on...what can i do?
snakehead
  • 1074 Answers
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Posted on Jun 04, 2007
  • 2336 Answers
SOURCE: I NEED A MANUAL FOR A DAEWOO DF4150p dvd recorder/ vcr combo please help
Click here to get the user guide for your device.
Posted on May 16, 2008
The Machine
  • 788 Answers
SOURCE: DRVR-B778S (Funai DVD Recorder/VCR Recorder Combo)
You stated having the unit unplugged in your problem description so you did do a reset already and that seems to have caused your problem. Unplugging the machine will probably not resolve your issue then. What does seem to be happening is corruption in the unit's firmware that is crashing it causing it to go into stand-by. Unfortunately I doubt there is any software on the Internet that will allow you to re-flash the machine's firmware. Unless you still have warranty available you will either have to live with it, replace the unit's main board (doubt a replacement can easily be found), or replace it with something new.
Posted on Aug 26, 2008
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Posted on Feb 10, 2009
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
Magnavox dvd vcr recorder will not turn on
check fuse inside on board for power u have to take a part
Oct 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
My new Toshiba DVD/VCR Combo has no built-in tuner
I'm not sure if you can do this using the timer recording, BUT....if you use the AV plugs (the ones with the red, white and yellow plugs) to connect the VCR to the TV, you can tape what is actually on the TV at that time.....you are using the TV tuner and just taping that on the VCR. As I said, I'm not sure if this works with timer recordings.....maybe if you leave the TV set on the proper channel? Try it and see if it works.
Nov 05, 2008 | Televison & Video
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't ower up
Unplug unit for about 20 minutes then plug back in and see if it works
Aug 27, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
