Question about Vizio GV42L 42 in. LCD Television
Pip and pop
Our new Vizio GV42L TV has the picture in picture.
We are having trouble in using this feature. We can get the PIP with
one TV channel and a DVD disc in use,(because we have a DVD hooked
up to the TV with a HDMI connection. We want to be able to watch two TV programs as we did on our old TV. Can you tell us how to get this feature
connected to our TV?
Thanks
M Weinhold
  • 1 more comment
  • mprevilon Jan 11, 2008
    I have the same problem, i don't know how i fix it.
    Please help us...
    Thnaks
  • atiya28 Jan 22, 2008
  • burr8 Feb 20, 2008
    WE HAD OUR OTHER TV RUN THROUGH A VCR TO GET THE
    PIP, BUT WE CAN'T REMEMBER HOW TO HOOK IT UP TO USE ON THE VIZIO. WE WILL KEEP TRYING BECAUSE WE KNOW IT NEEDS THE SECOND SOURCE.
    THANKS
  • 31 Answers
It sounds like your other TV had 2 tuners which allowed you to watch 2 programs at the same time. You can still watch two programs, but the second one will have to come from a second source. See below for the possible combinations that the PIP/POP feature can be used by this TV.
Posted on Feb 17, 2008
  • Curtis Hill
    Curtis Hill Feb 17, 2008
    Sorry, here is the non-cutoff version of the image.
How to work pip in vizio tv
PIP or picture in picture works in two ways with the original remote--new sets with this actually have two tuners in them, one for main picture and one for PIP picture, you can change channels in both, swap the PIP to the main picture or even have both side by side.
Sure its got the PIP? what is brand and model number ?
Oct 30, 2012 | Televison & Video
Vizio picture in picture
you can use the remote controller or the menu button in the tv panel. and then go to channel mode set up, select the PIP option.
Sep 15, 2012 | Televison & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
My remote for my vizio has no ''picture in picture'' button...how can i access this feature?
if your tv has this function the remote usually comes with that feature are you sure your tv has that funtion
Oct 26, 2009 | Vizio GV42L 42 in. LCD Television
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio sv420xvt pip
You have to be in 'TV' mode to access the parental settings option. Not sure why. When it asks for the code it's 0000
Jun 02, 2009 | Vizio GV42L 42 in. LCD Television
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42 in. LCD Television Logo
216 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
