Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
Touch screen blank -not eliminating but functioning
We are recording nicely battery exhausted we are try again and agian and we observe the touch screen is not iluminated but camera is working . without screen it is very difficult to recording kindly suggest solution
SONYHandycam DCR-HC 52E Mini DV Digital Camcorder
WHERE SHALL I GET A "DRIVER SOFTWARE" OF THE ABOVE MODEL.
Posted on Mar 26, 2008
Night vision camera dark
IF VIDEO WAS OK AT SOME PONT IN PAST, THEN CAMMERA BUILT IN ILLUMINATOR HAS GONE BAD (LIGHT BULBS BURN OUT YA KNOW)
IF VIDEO WAS NEVER GOOD FROM START YOU HAVE ASKED TOO SMALL A ILUMINATOR TO ILUMINATE TOO LARGE AN AREA , ADD MORE ILUMINATION TO AREA OR REDUCE OBJECT RANGE THAT CAMMERA TRIES TO SEE
Feb 25, 2014 | Lorex 4 Channel Business & Home Security...
Touch screen has stopped responding on our DCR-sr100. Is there anything I can try to fix this problem. We can no longer download video from the camera to the computer without a working touchscreen. Camera...
You could try removing the battery, and reinstalling the battery to see if the touch screen starts working again. If it doesn't, this device will need to be sent in to Sony for repairs.
Find a location to get your Sony product repaired, the Sony repair cost, and to initiate the repair procedure. Here is a link to Sony's Repair site: https://eservice.sony.com/webrma/web/index.do
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 14, 2011 | Sony Handycam DCR-SR100 Camcorder
My camera's finger touch panel doesn't work when I touch it to play back the records, how can I fix it myself?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 01, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Pv-l453d no picture from lens to lcd blank screen ?
Your device has the option buttons on which to select recording by observing the process from the user observation scopes. One option only could be observed at the recording session. On the other hand, disabling the option of observing a recording session on the scope lense automatically displays the recording session on the visible lense LCD screen area.
Manipulating the Camcorder is from the option buttons located along the sides of the camera. A switch on the menu area should make that experiece achievable.
Dec 02, 2010 | Panasonic Palmcorder PV-L452 Camcorder
My sony handycam DCR-HC26 is frozen on "clock set"
Hello i am hamid
I need a drive for Windows 7 Help me please
hamid.far12@yahoo.com
Jul 07, 2010 | Sony DCRHC26 MiniDV Digital Handycam...
How do I unlock the memory card for Panasonic DMC-TZ3. Suddenly locked - has always worked fine until today!
take the sd card out , there should be a loch on the left side when facing the card with the label up, slide the lock down and try agian or try a different card or else remove all power , wait 30 min , insert battery and try to see if the camera goes on (most pansonics have built in memory , so check if you can record a picture if yes then try the card agian )
Apr 30, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Mar 17, 2008 | Sony DCR-HC32E DV Digital Camcorder
Dew detected eject tape
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all Sony Handycam DCR-HC42E Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
126 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
