Back to:
Tags:
System Cooling
Generic problem for all System Cooling
Fan stopped working, replaced, still not working,... (by 3 users)
posted by zmom on Dec 27, 2007
I have a Compaq Presario 2200 and the fan stopped working. It had always overheated before that (guess that's an ongoing issue with these). We replaced the heatsink and fan and the fan does still not start although it can turn easily if you manually turn it. I guess it's possible we got a bad replacement fan but I doubt it. What else could be causing the problem in the fan? Are there other parts we should replace?
Comment by zmom, posted on Dec 27, 2007
Yes we did recheck all the connections, and we don't have the ability to test the fan. Assuming the fan and heatsink are ok (at least until we can get them tested), and that it is installed correctly, and all connections are being made appropriately, what else could it be? Is my motherboard just failing?
Comment by zmom, posted on Dec 30, 2007
Hi, well, we flashed the BIOS and the fan started working while that was going on, and hasn't turned on since. The next step we're going to try is to add some thermal paste. I will let you know if we resolve this so that this will be up for others to find a solution. Let me know if there are any other suggestions, please.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ksnvm, posted on Feb 28, 2008
Ihave a advent 7104 laptop and when i try and play games on it it turns off after a few minuites i have watche the temp and it goies up to 84degress then turns off can any one tell me what is the problem please the fan on the side of the lap top comes on but it still goes up only does it when playing games idle pemp is 60 degress thank you
Comment by nelsonsamson, posted on Jan 05, 2008
hello, i have the same problem with my compaq presario m2010us. it's keeps on overheating and when i check i noticed that the fan is not working. i just disassembled my laptop and took the fan off. is there a way to check the fan using other means? thanks
Best Solution
Thanks for Trying (70)
sweet_rascal
Rank:Wiz Wiz
Rating: 78%, 308 votes
did u check the connections? i mean the connection would be loose
Rating Locked! (?) zmom has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fan stopped working, replaced, still not working, laptop overheats:
I don't want to Accept this solution
Solution #2
munizcisco
Rank:Master Master
Rating: 79%, 12 votes
it could be on the mobo end. hook up the cooling fan to a molex connector.
Thank You!
Solution #3
posted on Feb 02, 2008
Not Rated (0)
nelsonsamson
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
what is a molex connector?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these System Cooling problems?
HP (158800-001) for Compaq Presario 1246,...
Have heard both 9.6 volt battery and 14,4 volt battery for...
Intel Vantec AeroFlow VP4-C7040 Premium CPU...
i what to inter (r) core (tm) duo cpu T2300 drivers plese...
System Cooling
i am tryin to install microsoft office but the system...
Averatec Sotec 3200 Series Fan with...
i have an cpu fan error that pops up and shuts down my pc,...
Toshiba Satellite Laptop Cooler
When I try to copy data - photos etc to a DVD I get the...
Loading problems.
Repair Service
Find System Cooling Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
