Question about Philips VOX130 Wireless Headset
Motarola razor does the philips vox 130 work with motarola razor phone?
0 characters
1 Points
I am wanting to change my motarola H12 to my new phone and i don't know my passcode for this device how to i find it is it on my old phone?
The factory set passcode is 0000 (zero's not O's). If you changed this then you will need to reset your bluetooth to go back to the 0000
Apr 20, 2011 | Motorola Mobility Motopure H12 Bluetooth...
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
Jan 27, 2009 | Cardo scala-500 Wireless Headset
I can not pair my razor v3
Go to menu. Then to Connection. Click on Bluetooth link. Go to setup. Then click on find me. Then you should be able to sync your phone to his. For him to sync to you quicker, he can click on sync under connections in the menu. Then you should be able to send your pics, phonebook, the whole nine yards! The default pin to conect them is four zero's.
Jan 10, 2009 | Motorola Mobility HS810 Consumer Headset
Has been working fine, now Razor phone cannot find it.
hoping this helps...
Explorer Series: 220,320, 330, 340, 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
The passkey is 0000
Sep 18, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Motarola H500 headset, not syncing with PS3
gotta hold headset power down while device syncs with it this is the only way to sync and save settings to memmory card
Jun 01, 2008 | Motorola Mobility H500 Wireless Headset
Unlock razor
how do i unlock a razor from CINGULAR TO T-MOBILE????
Feb 14, 2008 | Motorola Mobility V3x Razr GSM World Cell...
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
Razor phone
i can't get this name off me display screen
Mar 20, 2007 | Motorola Mobility Razor Behind-the-Head...
I cant scan phones using my bluetooth.
reset your blue tooth , pair it agian with your phone. remove all other blue toohts and pair it again. i hope that works .
Feb 17, 2007 | Motorola Mobility Razor Behind-the-Head...
Philips VOX130 Wireless Headset Logo
23 people viewed this question
Top Philips Headsets Experts
 Mike M
Mike M
Tom Chichester
Are you a Philips Headset Expert? Answer questions, earn points and help others
