Question about Samsung SyncMaster 245BW Monitor
Monitor my monitor disply is shivering when it was runninig.
  • unquiet Jan 08, 2008
    My monitor has this "shivering" too. About a dozen or more horizontal lines running the full width of the screen. Don't show on a white background but anything else and they're reasonably obvious. Worse after the monitor's been switched on for a while
  • jstanchos Mar 10, 2008
    I have this same problem with the lines showing up. Sometimes it gets so bad that the monitor freezes or fades in and out locking up. But if i can open my outlook fast enough witch has a white background the problem seems to correct itself.
2 Suggested Answers
  • 85 Answers
SOURCE: monitor
Unquiet,
This issue has do do with your horizontal output chip inside your monitor screen. The Horizontal hold isnt running at 60hz anymore that is why you can see lines, kinda like if you watch tv threw a old black and white video camara. I would suggest looking at getting a new monitor. There isnt alot you can do and the prices on most monitors now days are pretty reasonable.
Posted on Jan 08, 2008
Shivering screen
Shaking or trembling of a computer screen is often caused by interference from another device that is within a couple feet.
It can also be caused by another monitor close by.
If the removal of these objects does not stop the trembling, the monitor may have built up magnetism and need to be degaussed.
Find the menu button for your monitor.
This is usually on the front of the monitor.
It is sometimes on the side of the monitor.
Push the menu button. Scroll down until you find the screen option.
Select "Screen."
Scroll down to the degauss option.
Select "Degauss."
Select "OK."
The screen will make a tuning sound, as if you hit a guitar string.
The screen will shake and vibrate.
The shaking should now be gone.
If it is not, it will need to be looked at by a professional.
May 04, 2013 | HP Computers & Internet
Monitor
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Crt screen shivering with some noise inside
From the description the high voltage inside the set is arcing that would explain the shivering in the picture and the noise you are hearing, the monitor is on the verge of failure and should not be left unattended while it is running.
Apr 02, 2012 | Computers & Internet
Just monitor power on disply comes but after some seconds disply is gone
On Samsung 740 this is a very common problem with the high voltage impulse transformator in the invertor block. That needs to change.
May 16, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
My screen keep on shivering and i can't stop it
Its like Hororizontal wave and its only happen once in a while not all the time!
Mar 16, 2010 | Gateway HD2201 22" LCD Monitor
Vertical white wide band - Shivering fonts
Unfortunately that sound like a defective LCD panel. You can verify this by plugging the system into an external monitor. As long as the shimmering band does not appear on external display then it is the LCD. If it is under warranty I would suggest taking it into Apple.
Aug 16, 2009 | Apple MacBook Air Mac Notebook
Screen shivering
Time to get new monitor.
Aug 24, 2017 | HP Computers & Internet
No disply monitor
Hi, check all connection monitor power cord and push socket and tightened two screw reset computer .
Jan 31, 2008 | Computers & Internet
Samsung SyncMaster 245BW Monitor Logo
63 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
