Question about Microsoft Xbox 360 Console
Controller want 2 play 2 play mode 1 cotroller fine the just flash green
  • jamesandmark Nov 28, 2008
    the controller that came with the xbox 360 is fine, any other controller cannot sync, it just flashes green
  • stevie_hughe Nov 28, 2008
    wireless!!!!
    Problem Solver:
  • 10 Answers
Is the controller wireless or wired?
Posted on Dec 27, 2007
The video 1 and video 2 display flashing simultaneously back and forth...cant play dvd cause it continually switches back and forth
Try a different resolution setting.
You can also try playing the dvd into another device to confirm dvd works fine.
Check output\mode of device as well.
I assume, you inserted another dvd and it worked fine, then you inserted the "questioned" dvd is it flashes back and forth.
Try another video mode or setting change on device.
Jul 22, 2014 | Televison & Video
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
Optoma HD72 flashes red and green. I changed the lamp but the problem wasn't resolved. Any input would be greatly appreciated.! Greg
I had the same problem with flashing colors after playing for awhile. The following helped:
1. turn off bright mode from menu.
2. keeping the back side of the projector flat. I had it raised up about 3" on the backside before, not sure why but it worked fine when flat.
Hope these help you also.
Apr 11, 2009 | Optoma HD72 Multimedia Projector
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 14, 2009 | Directv RC23 Remote Control
You just dropped me without answering my question or really even trying
I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
10812, 10702, 10030, 10672, 10060
As you can see, they are 5-digits for the direct remote, not 4.
This should help!
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | One For All URC-3021 Remote Control
Controller
you have to press the connection buttons, one on the controller and one on the xbox 360, the one on the controller is located on top by the triggers next to the cartridge insert port right by the left button, it has 3 wavy lines next to it, when you press it, the controller will light up and go in circles. After that quickly press the button on the xbox 360 located under memory unit A, to the left of the disc eject, then the xbox 360 lights will go in a circle then automatically connect. If it doesnt work at first, try it again, but quicker.
Nov 28, 2008 | Video Game Consoles & Games
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 26, 2008 | Audio Players & Recorders
Menu Options
sound or volume can be lowered or turned off using zoom control button
Aug 30, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
