Question about HP OfficeJet 6110 All-In-One InkJet Printer
Replacing ink isnt taking black ink cartridge
  • wkyfals Oct 23, 2008
    Two new ink cartridges have been inserted both react the same way the window tells you to, "remove and check the cartridge", cleaned the contacts per the instructions no work
Make sure you have correct ink cartridge in your hand.
try to clean the cartridge contact points and carridge contact points.
Posted on Jan 04, 2008
Not printing at all
The old ink got dried up on the contacts. Remove the ink cartridge and using a cue-tip with water clean the contacts where the ink cartridge contacts the other part. This would be a good start. if the ink isnt coming off easily with water try alcohol, its cheap at most dollar stores just watch out for sparks and flames around alcohol and just pour out small amounts and put container away before use.
Jan 21, 2014 | HP OfficeJet K80 All-In-One InkJet Printer
Reset inkjet printer lexmark x2630
make sure the ink isnt dry. take a tissue and put the inkjet on it. apply slight pressure, lift up and look if there is ink on the tissue. do it a few times. if no ink on tissue it is drry replace. also clean the copper contacts on printer and inkjet
Jun 28, 2013 | Lexmark X2600 InkJet Printer
Lexmark x2650 isnt recognising the black ink cartridge
There could be two reasons for this 1. take out the black ink cartridge make sure you have taken the plastic sticker off. 2. The contacts at the back of the cartridge might be damaged. in which case you will have to get a new ink cartridge.
Mar 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
Black cartridge is new. registers low ink level and does not print at all.
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Mar 17, 2011 | Dell 962 Photo All-In-One InkJet Printer
I intalled new ink on my computer and it says to remove tape from cartridge when I all ready did and it will not work
Rick
Jan 10, 2011 | Dell 962 Photo All-In-One InkJet Printer
I have the HP photosmart C6280 printer.. 2007 edition and it has all different color ink cartridges, the yellow ink is almost out so it will not let me print anything. I am just trying to print off a word...
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://www.fixya.com/support/t6288403-hp_8050_printer_message_says_color
Sep 30, 2010 | HP Photosmart C6280 Printer
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
Replaced all cartridges will not print black
Before you replaced the ink cartridge, did you let the ink in the previous cartridge run completely dry? If you did, then the printer heads are completely dry and it will take awhile for ink to start flowing again.
Jul 31, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Refilled Ink cartridge but the printer says there is no Ink
you refilled or purchased a new cartridge? If you refilled ; did you do it after the printer told you it was out? The cartridge electricial would have to be reset. How to do that is a guarded secret for Canon. Buy a Canon One and replace Cartridge, would one on solution.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14991
Jan 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
