Question about SanDisk Sansa e250 MP3 Player
Black screen sansa sandisk
Hi, when I plug my sansa the wheel turns on, but thats all!, it remains like that, What can i do? hhhheellllllppp.
my m240 turns on but none of the functions work...no music plays. Worked fine for months.
    Sergeant:
  • 279 Answers
Have you tried connecting it to the USB port on your computer without the battery in? If not, remove the battery and try that. Hopefully this will make it display USB Connected. Let me know if it doesn't (as the rest of this advice won't work if it doesn't, and we'll have to try something else).
If it does, disconnect it and hold the "Menu Button" (aka Power Button) for 45 seconds, then reconnect it to USB.
After that it should say USB Connected again. At this point, put the battery back in and see if it works.
If it does display USB Connected as I suggested above, but doesn't work with the battery in, you'll have to get a new battery and repeat the steps above before installing it - your battery is bad.
If it does work after this - great.
If you can't get it to display USB Connected, then the battery is not the problem - let me know and I'll see what else I can come up with to try.
-Dyllan
Posted on Dec 27, 2007
    Guru:
  • 1,894 Answers
Perform recovery mode on the player and create a file named sansa.fmt and put that file in the 16 MB format that should reformat the whole player after you have put that file in the drive and unplugged the player from the computer. After that has been done try to update the firmware of the player.
  • 1 more comment
  • dewan nafees ahmed Dec 27, 2007
    i found this solution from fixya itself. u may have even searched fixya for existing solutions brother.
    if u need i shall give youe the link of the thread from where i found this solution
    i gave you the solution based on your problem here you mentioned that you dont have m240 turns on but none of the functions work...
    so if nothing goes normal formating fully makes it a fresh product.
  • dewan nafees ahmed Dec 29, 2007
    what happened>?
Everytime i turn it on it shows the sandisk startup and company and it does that over and over again when i plug it into the USB it doesnt even turn on
when i switch it on .sandisk initialising.showing sansa details after that it remains on .no other functions working
Sep 03, 2010 | SanDisk Sansa m240 MP3 Player
Sansa e260 only wheel light will turn on, screen remains black
you need to contact Sandisk and have them walk you through this problem, www.sandisk.com
Mar 24, 2009 | SanDisk Sansa e260 MP3 Player
Blank screen
Typically this is an indication that your battery is dead. If the music is still playing but the screen is blank I would say a hardware failure and replacement would be the best option.
Jan 06, 2009 | SanDisk Sansa m240 MP3 Player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 11, 2007 | SanDisk Sansa e250 MP3 Player
Stuck in "sandisk initializing screen"
To those that are having problems with the MP3 player not being recognized. With Windows XP there is a little Icon on your Systems Tray that is called the "Safely Remove Harware Icon". Not using this Icon when unpluging MP3''s or zip drives can cause your PC to no longer recognize it. Toshiba Satellite laptops are known for this, others probably have the same problem. The solution here is to install the latest update of the ACPI Flash Bios for the Toshiba Satellite computer. Maybe this is also the problem with other PCs. To prevent these problems allways click on the Safely Remove Hardware icon before removing the MP3 player or any USB flash drive
1 With your m240 set to MSC and connected, go to "My Computer" and "right click" on the "Sansa m240" icon and select "Properties"
2 In that window, select the "Hardware" tab
4. In that "All Disk Drives" window, highlight the "Sansa m240" drive and select "Properties" (at the bottom)
5. In that window, select "Policies"
6. And there, set it to " Optimize for Quick Removal" and click OK and OK again
Dec 02, 2007 | SanDisk Sansa m240 MP3 Player
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Mp3
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240''s there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that''s frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately. <>
May 04, 2007 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
there are 2 usb choices on the sansa m240 one is msc the other is auto detect. msc is for downloading new upgrade software i beleive , because thats the setting sndisk has you set it on to download new upgrade software .it stands for mass storage class .it may need to be on auto detect .
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
R u holding the holding the Menu button down for about 3 seconds?
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
