Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer
Problem for Brother Multi-Function Center MFC-240C All-In-One InkJet...
My printer says install magenta what does that
By smejia14 on Oct 14, 2009
my printer says install magenta what does that mean
Best Solution
posted on Oct 14, 2009
Very Helpful)
schramm
Rank: Wiz
Rating: 79%, 27 votes
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
kitajib
Rank: Guru
Rating: 87%, 220 votes
You can download the user manual at
www.brother-usa.com/.../Users%20Manual/UM_MFC_240C_EN_249.PDF
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Improper Setup
DO NOT touch the area shown in the
illustration below.
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically reset the ink
dot counter.
Note
If the LCD shows Install after you
install the ink cartridges, check that the ink
cartridges are installed properly.
Please rate this solution. Thanks.
Was this helpful?
Yes
No
Popular Solutions for Brother Multi-Function Center
Questions and Unsolved Problems for Brother Multi-Function Center
Do you recommend Brother Multi-Function Center MFC-240C All-In-One InkJet Printer?
Answer
Answer
I have an MFC-120C and cannot scan on the desktop I'm using. It worked on my other computer but... (More)
Answer
my brother MFC5048CN is saying it is going through a routine maintenance function and to refer to... (More)
Answer
When I try to print, the LCD says "Print unable 52". The manual says I need to clean... (More)
Answer
I have a brother MFC-210C and I just changed all the inks and I'm still getting a low ink on the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
