HP Compaq Presario v4000  PC Notebook
Problem for HP Compaq Presario v4000 (PL696AV) PC Notebook
My Compaq laptop will not boot up. It gets only
By sunfrostice on Oct 14, 2009
My Compaq laptop will not boot up. It gets only as far as the Windows screen, and that very slowly. I have removed the battery and power cord while holding down the power button about a minute following the disconnection--it didn't help.
What can I do next?
Solution #1
posted on Oct 19, 2009
Not Rated)
conrix
Rank: Wiz
Rating: 90%, 32 votes
This is only a symptom of a falire un the hard disk, you can either format and install new windows or simply replace the hard drive hope it helps.
Was this helpful?
Yes
No
Solution #2
posted on Oct 14, 2009
Not Rated)
relojmesa
Rank: Wiz  Computer Hardware  Expert
Rating: 74%, 28 votes
Tturn on your computer, then, before the windows boot screen appears, press the F8 key, this should bring up the start options , if it does not, turn off , turn back on and try again.
On the start options use the up/down arrows on keyboard to select "last known good configuration", press the enter key. Windows should start as normal if it does not do the process again but instead select "safemode" .
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario v4000 PC
Questions and Unsolved Problems for HP Compaq Presario v4000 PC
Do you recommend HP Compaq Presario v4000 (PL696AV) PC Notebook?
Answer
Answer
acer notebook will not boot up
Answer
need to get sata to ide in my bios?
Answer
I have a Dell Inspiron 8200 with a Matshita CDRW/DVD UJDA740 and it has stopped burning cds. It now... (More)
Answer
looking for compaq 700 manaul so i can work on computer
Answer
keeps giving errors of not finding files on the installation cd, changed cd, same problems
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq Presario v4000 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
