Question about Freezers
Fridge freezer. my fridge temp has rise to 16degrees.it fluctuates around when the door is open.the freezer still works however ice is building up on the bottom shelf. until recently there have been storage boxes on top of the appliance.I was wondering if this may of blocked the circulation?Any advice would be welcome, thanks paul.
  • Anonymous Nov 07, 2008
    ihave a frost free fridge freeze and the fridge has started to freeze the freezer is still ok what can the problem be
  • Anonymous Mar 13, 2014
    prestige fridge freezer water under bottom box
    Sergeant:
  • 288 Answers
I had to look up where you are from. Being the U.K. you mean 16 celsius, right? If the problem began after you removed the boxes, I don't think its a circulation problem. The ice build up on the inside, and the freezer being good but not the fridge, makes me think the defrost isn't working. I can help you check the controls for this, but without a volt/ohm meter you should call someone.
Posted on Dec 31, 2007
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
FFB6187
Try rearranging all items inside fridge and freezer so that air may circulate around all items easily and then check seals on doors and ensure doors are closed completely and not leaking cold air. Also do a complete thaw/ defrost. You can remove the plastic coverings and ensure all ice is defrosted. Using a hair dryer will speed up thawing/defrosting process.
Nov 06, 2013 | Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Freezers Logo
299 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
