Home | PC Chips | M825G Motherboard | In device man...
PC Chips M825G Motherboard
Problem for PC Chips M825G Motherboard
In device manager:pci simole communications
By ttcomm on Oct 14, 2009
in device manager:pci simole communications controller not configured correctly.reinstall drivers. from where do i download drivers
Solution #1
posted on Oct 15, 2009
Not Rated)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1919 votes
Most likely the PCI simple communication controller is the onboard LAN or it might be a modem if you have one installed. My bet is it’s the LAN controller driver. You need to enter your bios first and make sure your LAN is enabled. Press the Delete key as your system boots to enter your bios menu. See page 30 in your manual. Make sure your Ethernet Device is set to [Enable].
Open the link provided below by left clicking once on the PC Chips link;
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=4&detailid=250&DetailName=Driver&DetailDesc=M825G(V8.0a)&MenuID=39&LanID=2
Create a folder on your desktop and name it LAN.
Scroll down to; LAN Driver, VIA VT823x onboard. Download the driver and save it into the LAN folder. You will need to uncompress the file named: VIA823x_832A.zip If you can't uncompress the file you can download a free 45 day trial program named WinZip. Open the next link; http://download.cnet.com/WinZip/3000-2250_4-10003164.html
With WinZip installed you can right click once on the file named VIA823x_832A.zip and left click once on Extract here.. From within the pop-up window. A new folder will create its self named: VIA823x_832A. Open the folder and find the winsetup.exe file. Double left click on the .exe file & it will install the drivers for your controller.
Restart your system. Update windows after restarting.
Cheers!
Mike
Was this helpful?
Yes
No
Solution #2
posted on Oct 14, 2009
Not Rated)
PaulMo
Rank: Wiz  Computer Components  Expert
Rating: 82%, 367 votes
That would be from the motherboard's website; pcchipsusa.com
Was this helpful?
Yes
No
Popular Solutions for PC Chips M825G Motherboard
Questions and Unsolved Problems for PC Chips M825G Motherboard
Do you recommend PC Chips M825G Motherboard?
Answer
Answer
could you please describe the m2v sound output plug spec for 5.1 socket as fitted to the asus m2v... (More)
Answer
I need a CPU mount. The plastic mount to clamp the CPU is broken and I need a new one. Where can I... (More)
Answer
how do i change the memory spee rom 533 to 667 my945gcm478 motherboard help paul
Answer
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Chips M825G Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14697
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
