Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Green Light blinks no picture
How do I know that the bulb is bad by looking at it. Last time it blew
it actually made a loud popping sound and it was under warranty and
by replacing the bulb fixed the issue.
No popping sound this time and the wire on the bulb looks unbroken.
Is that all I look for in the bulb?
  • Anonymous Dec 30, 2007
    no picture this is the second lamp.i put in.
What small blue lever?
Posted on Jul 01, 2008
    President:
  • 4,402 Answers
Check that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
Loud pop
Check the lamp.
Pull it out and look at it.
More than likely the lamp has shattered inside the set and needs replaced.
Bulb replacement is made for consumers and can easily be replaced.
Need any more information, respond to this post and I will reply.
Dec 30, 2007 | Panasonic PT-45LC12 45" Rear Projection...
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
Pop then dark screen - no picture... New lamp installed and still no picture
Yes you are correct, I have seen this many times. 6 flashes is the thermal fuse
Mar 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
