Question about Sony Playstation 3 (PS3) Console
Will not see any cd even cleaner
How do i do a factory reset , holding down the start button does not work
    Problem Solver:
  • 10 Answers
Go to the System Settings at the second to left menu on the Cross Media Bar on the PS3 start up screen, you can do one form there.
Posted on Dec 28, 2007
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at:
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
Why will the tablet not move past the initial start up screen?
It could have hardware problems. It could have software problems. To troubleshoot software problems, when on the initial start up screen carefully introduce a paperclip end into the *Reset* button hole until you feel a little click. Your device should then turn off automatically. Some start up again automatically, some don't. Give it a minute or so and it it doesn't start back up by itself. Push and hold the power button as usual.
This should clear up any software problems and this doesn't cause you to lose any data or changes you've made.
Hardware problems such as a memory chip gone bad will not be helped by a Reset Button reset nor will they be helped by a *Factory Reset" which is done by holding down a combination of Volume(-) and Power buttons to get into the Android factory reset options text list. These are drastic and will cause you to lose any and all personal data and changes you've made to the device. A factory reset will put the device back to new condition. But, alas, even a factory reset will not help if you have hardware problems.
May 10, 2015 | Tablets & eReaders
How to get a nobis NB07 it worked fine then it froze during boot up at go so I shut it down by holding the power then after it shut of I pressed factory reset now it won't turn on at all even let it c
Question: Were you trying to jail break it? I found a forum that may have useful information to reload the firmware.
Otherwise, there are often external buttons on the sides of the device that may allow you to get it to reset and recover.
Best of luck... Nobis NB07 and DA 741QHD rooting and ROM thread
Feb 03, 2015 | Cell Phones
How do i get past a screen lock (draw pattern)
Remove battery. Install back. Hold down power and volume down button until it starts, immediately release the power button and it should go to reset screen. use volume button to scroll down to factory reset. select with power button.
Jan 10, 2015 | Samsung Cell Phones
How do i factory reset my digiland tablet
here is a step by step I found :)
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process
Sep 13, 2014 | Tablets & eReaders
How to get my cromo inc tablet to power on after i factory reset it
Odd, but try this: Some tablets do not fully shut down, even though the screen goes blank. Hold down the power button for 30 seconds, wait 15 seconds, and then try again to power up (hold power button for 3-5 seconds). Wait patiently for the power up, as power after factory reset may take longer than a 'typical' start-up. Good luck!
Jul 18, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
Htc first won't boot
Try holding volume Up and volume down together then the power button----hold all three until vibration starts.......that should get you to a factory reset.
Dec 04, 2013 | HTC First Android Smartphone AT&T Locked
My HTC HD2 is stuck on the homescreen, It want let me get in the start menu to get in settings to do a factor hard reset
You can do factory hard reset for HTC HD2 even when it is turned off. But it will erase all contacts,downloaded contents and user informations. The phone settings will be reset to factory default.
These are the steps to hard reset HTC HD2.
  1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it.
  2. Release the VOLUME UP and VOLUME DOWN buttons.
  3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Mar 06, 2011 | T-Mobile Cell Phones
Hard reset HP H114/111/100
bought it from a friend and he forgot password too. how do i reset it?
Apr 17, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
