Question about Brother Office Equipment & Supplies
Brother 5140 faint print
Changed drum and toner no go still faint
I had the same problem and I just fixed it.
It turns out that the toner cartridge I was using was not an authentic brother cartridge. It was an Office Max knockoff.
I replaced the knockoff with an original BROTHER toner cartridge and BAM! Right back in business.
What tricked us for so long was that the knockoff worked for two weeks before it conked out, so while we were looking for the problem, we kept saying to ourselves, "No, it COULDN'T be the toner cartridge. It's practically brand new."
Hope this helps.
Posted on Jan 20, 2009
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
Brother hl 5140 drum light comes on then off every 4
With the front cover open, press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the go button, then close the front cover.
This will reset the drum counter.
Mar 27, 2010 | Brother HL 5140 Laser Printer
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Blank white 'line' on printed output
Some of the brother printer use a toner cartridge that does not have a drum, have u replaced the drum recently, or does the toner cartridge have it installed? If it has a seperate crriage for the drum, let me know.
Dec 11, 2008 | Brother HL 5140 Laser Printer
Changed Drum and Print Quality is Worse
The sign of a low toner is bizarrely enough, a very dirty print out covering who page.
Feb 29, 2008 | Brother HL 5140 Laser Printer
278 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
