Dell TrueMobile 2300 Wireless Broadband Router
Problem for Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
I changed my default SSID and then enabled WPA,
By kdak88 on Oct 14, 2009
I changed my default SSID and then enabled WPA, but now the wireless light is off on my wireless router and I can't connect. Please help.
Solution #1
posted on Oct 23, 2009
Not Rated)
jhonny82
Rank: Master
Rating: 75%, 4 votes
Please try connecting a cable b/w your computer and router. Check whether you getting a internet connection or not.
If yes then change the SSID of your wireless name make sure mode should be G and B. Channel should be 11.
In case if still it not working then change the security option to WEP and type the security key.Please write this key on paper for future use.
Get back to your computer get in to wireless setting windows refresh it. It will ask you for key type the key click connect then you'll connect to your wireless network.
In case you get an error " wireless zero configuration".
Get in to run box run>services.msc>look for wireless zero conf... right click then click on start or restart.
then again go back to wireless connection window refresh it then check you will find your network name there.It will ask you for a key type you wireless key there and connect.
Hope this will resolve your issue.
Was this helpful?
Yes
No
Popular Solutions for Dell TrueMobile 2300 Wireless
Questions and Unsolved Problems for Dell TrueMobile 2300 Wireless
Do you recommend Dell TrueMobile 2300 Wireless Broadband Router (TM23001)?
Answer
Answer
wireless light not on, no wireless signat to computer
Answer
Hi, I am not sure, but I think that I've got the same/similar problem...just with my iPod and... (More)
Answer
When installing anew computer, everything but the router worked fine. I used the original install... (More)
Answer
The Dell router will not communicate with the Comcast modem. The modem is working properly. The... (More)
Answer
It has worked okay for 2 years, (every once in a while it would cut out-and I could only access... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell TrueMobile 2300 Wireless...:
Top Router Experts
Rank: Guru Guru
Solutions: 1405
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
