Question about Microwave Ovens
GE Profile Spacemaker 2.0 Microwave
I have a GE Profile Spacemaker 2.0 Microwave Model JVM2070BH002 manufactured in February 05. Recently, it seems that the control panel where you enter the cook time, etc. has been shorting out. One time, it reset to all 0000's and every light on the panel was lit up. This morning, I put a cup of coffee in it to warm, it started fine but shut off after about 2 seconds. I tried it again and same thing happened. Any idea what the problem could be? Any help would be greatly appreciated.
  • 6 more comments
  • time2bounce Dec 29, 2007
    I have a GE Profile Eterna Spacemake "over-the-range" microwave and the last 2 weeks when you try to use it, it will run for a couple seconds and short out leaving no error messages in the display. We just have to reset the stupid clock and date every single time but it will not work at all more than 2-3 seconds. It was manufactured in March of 2005 and we actually purchased it from ABC Warehouse in Aug./Sep. 2005 and had it professionally installed. GE wants $69.95 for just the service call fee. Any helpful trouble shooting tips would be helpful. I know for sure it is not anything to do with our electric.
  • Anonymous Jan 04, 2008
    clean top of the microwave. Food particles are killing it.
  • garden45 Jan 14, 2008
    I did hold the vent at the top open and vaccuum it. There was a ton of dust. It works intermittantly now, sometimes it does, sometimes it shuts off. Is there something else I need to remove to clean?
  • garden45 Feb 17, 2008
    Okay, we have taken the top vent off and vaccumed everything. I've also cleaned the inside of the microwave where the holes are. I rarely use it except to boil water or for popcorn so it was pretty clean. It still is shutting off after a few seconds. Any other suggestions?
  • btboeger Dec 21, 2008
    We have the same problem, it seems to work some days and others it kicks off after about 3-6 seconds of usage. We read something about static paper, we're not sure what exactly this is or if anyone else has had this remedied with the static paper. Any help would be greatly appreciated, they say it is 75.00 just for a service call.
  • grayseasmom Dec 31, 2008
    where do you apply the static paper? the back of the control board? I would really appreciate the info !!!!
    Thank you
  • hcbgwa Jan 08, 2009
    I have a GE Profile Spacemaker 2.0 as well, and it has developed the same issue of cutting off. Where exactly does one put this "static paper," and why does that solve the problem? I've already had to replace the magnetron on this unit (under warranty) because it was leaking and shorting out the control panel. GE certainly must know about this problem.
  • Anonymous Mar 17, 2014
    We had a tech look at it who said the control board was bad. We've replaced the board and when we enter time and push start, it makes a clicking sound that comes from the board area.
Clean the inside top of the microwave. There is food stuck to the top and is killing your microwave cook time. I had this same problem and was fixed $125.00 Later. Good luck
Posted on Jan 04, 2008
How do you get to the digital display on that model? Are the screws under the microwave on the side of the display? or next to the display when you open the door? I have screws in both places...
Posted on Dec 27, 2011
  • Microwave Ovens Master
  • 9,098 Answers
WARNING: The "technique" of using "anti-static paper" or anything else to try to shield the control circuit board is not a fix, but a band-aid at best...
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
The shielding may keep the interference out of the controls, but it's still being emitted, and the magnetron will eventually go bad.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Posted on Jun 28, 2009
What is this anti static paper? I have the same problem and would like to go out and buy some.
Posted on Sep 10, 2008
Hey, "timebomb" thanks for that comment but there is absolutely no food stuck there but we did fix it using another persons comments. We went to a local computer repair store and they GAVE us that anti static paper for FREE and we opened up the digital display and covered the inside back portion with the paper that I mentioned and IT TOTALLY WORKED our microwave has been working perfect now since we fixed it on like January 3rd, 2008. We are shocked!!!!!!! Boy, my interned bill paid for itself this month because after doing research we knew that it was going to end up needed a new magnatron plus labor costs, I would have hated to see that bill. WHAT A JOKE, GE definitely knows that this is happening. They SUCK!!!
Posted on Jan 14, 2008
  • time2bounce Jan 14, 2008
    I meant INTERNET bill paid for itself this month because with out it we would have just waited for GE to send someone.
Tip
Profile series kicks out during operation
My GE Profile series Spacemaker Microwave, model JVM2070BH002 after we set the cooking time will kick out after about 3-5 seconds. This is sporatic. It will work for a week and the kick out for 3-4 times.
on Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Key pad on my GE Profile Spacemaker 2.0, Model JVM2070choo1 does not respond.
1) the control board is faulty. however you can try to clean the keypads for dirty , oxide, or corrosion, Of course you must try to unplugged the power cord and discharge the capacitor see the diagrams.
God bless you
7_15_2012_12_27_54_pm.jpg7_15_2012_12_28_09_pm.gif7_15_2012_12_28_43_pm.gif7_15_2012_12_29_12_pm.gif
Jul 14, 2012 | GE Profile Spacemaker Over-the-Range...
GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. em.ka.ventures@gmail.com I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
Jun 01, 2012 | GE Profile Spacemaker Over-the-Range...
I have a GE Profile Spacemaker XL 1800 JVM1860SD microwave that recently started making a zzzzzzzz noise whenever it is plugged in. The light also seems to be stuck on. The noise seems to be coming from...
That would be a defective electrolytic on the control circuit board.
We see and repair this problem often with our $39.95 service. Details are here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jul 09, 2011 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
Panel periodically acting up - says there is a short in the panel
Hello there:
what this is trying to tell you is that your control panel is starting to go out due to a failure in the controle assembly
yes it is feasable to replacethe panel youwill just have to contact the manufacture of the microwave and get a replacement panel/ controle board ok
I hope that this is very helpful for you
Best regards Michael
Nov 21, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
1,500 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
