Question about Compaq Presario M2000 Notebook
Windows installing problem in compaq v6409tu laptop
I am not able to do format when i made sata drive enable
  • 102 Answers
Go back into your your bios and disable SATA.
You must have IDE enabled if you don't have a SATA drive.
Once IDE is enabled again you should be able to format your drive.
Posted on Dec 27, 2007
I am trying to format my hard drive on my stalite l305=s5875. i shows the hard drive in bios but when the windows disk looks for it theres nothing there. no hard drive appeares
If your laptop has a SATA hard drive then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | Toshiba Satellite L305-S5875 Notebook
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
I want to install windows xp-2 in my laptop presario cq42 notebook, i have a proble with hard drive for sata disable. in this laptop the bios not show the sata disable feature. so i want to disable this...
Aug 11, 2011 | Compaq Presario Notebook
I have not continuing windows xp. if i start xp installation then the blue screen appears. i want to know to change bios setup on sata mode
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 27, 2011 | Compaq Presario Notebook
HP Compaq 7300. Tried to load Windows XP but before installation cannot see HDD, yet in BIOS one can do HDD integrity check and akk ok. Where is the problem?
You need to format first. If install cannot see drive, drive maybe faulty, or need an F6 driver SATA.
www.custompcblog.com/.../installing-windows-xp-sata-hard-drive
Check out link above.
If you cannot, format and "See" the drive, then it is most likely faulty. To test you must get a SATA/IDE USB Dongle, they are a few dollars. Connect uo the harddrive you have taken out of the laptop, and connect up via the USB poet, on another PC. IF it installs and shows up, then the problem may lay with your laptop, however, at this point, if you want, and drive is blank or you don't want anything on the drive, use Windows, and Format the drive, NTFS, now. Then take it back to laptop and try to reinstall. IF it STILL will not "See" the drive, then the laptop is definitely faulty. if it does, continue on and install Windows. Remember to set BIOS to Boot from DVD first. and set back, at finish of install.
Mar 28, 2010 | HP Compaq nx7300 Notebook
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Windows instaling problem
When you disable for installation it normally does not work correctly when enabled again. Go to Hp's website and download the SATA software. You will need a floppy drive. The driver for it extracts to the floppy. If your laptop did not come equipped with a floppy you will have to use an external usb floppy. No off brand it has to be a name brand. Normally the generic floppies do not work. Once you have the software extracted to the floppy. Boot the computer to with xp cd. When the blue screen displaysa message accross the bottom with say "Press F6 if you need to install a third party SCSI or RAID driver. The computer will read the floppy and select one of the choices preferably windows default.
Hope this helps you
Dec 28, 2007 | Computers & Internet
Windows installing problem in compaqv6409tu laptop
you have to go to BIOS settings and check your sata hard drive setting. To get into BIOS you have to press Delete button(normaly) when you start your PC.
Dec 09, 2007 | Microsoft Windows XP Professional With...
Installing widows XP
first, have a WIN XP startup disk...created by (in windows)  inserting floppy and right clicking choosing format and select option "create MSDOS startup disk"
first backup all personal files...then restart and bypass to DOS screen at startup...try using F8 key just after BIOS screen...then select startup to DOS prompt only...then run (from the floppy disc) format c:
now you should have a nearly bare hard drive. repeat above steps and this time choose "startup using CDROM drivers"...then insert CDROM and redirect to that drive letter (d drive?) and run setup.exe.
Oct 30, 2007 | Compaq Presario C552US Notebook PC
Compaq Presario M2000 Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
