Question about Nintendo Wii Console
Wii bluetooth cant get any controllers to sync up spoke to nintendo they say its the bluetooth failing have you got any fixes for this or does it have to be repaired. thanks Illy
  • 1 more comment
  • KeSaCoMe Dec 27, 2007
    Exact same issue. Bought Console 2 weeks ago, controller included + 1 extra controller purchased - worked for 10 minutes, then started flashing blue. Have tried all re-sync options...nothing working.
  • Knaphill2007 Jan 27, 2008
    Two handsets not working, reset the console, and the handsets - only after switching off wii for a few minutes could we get one handset working. any other tips
  • Olivia Corrigan Jun 11, 2008
    Only got wii at xmas and has been used a handful of times, both new controllers with new batteries, the blue lights flash for a few seconds in both and then go out, have pressed sync buttons on them several times, nothing working, help!!! Olivia.
  • 167 Answers
Unplug your system for a minute or two. Mine had this problem too. Called nintendo and they told me to do that andtell them my wii system serial number.
Posted on Jan 25, 2008
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
Aug 21, 2014 | Nintendo Wii Remote Controller
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
I cant get my wii remotes to sync after i replaced the batteries
Try this: 1-turn on the wii from the FRONT power button 2-hold the SYNC button under the SD cover (on the wi, not the remote) for 5 seconds 3-Attempt to SYNC the wii remotes again
If that fails: 1-Replace the wii remote batteries 2-Repeat above steps
if this still doesn't work, reply to this, and I will help you more
Jan 25, 2011 | Nintendo Wii Console
We cant get the wii remotes to work for our wii
If both of your remotes are not syncing to the system you will have to get your bluetooth replaced. You can either send this in for repair or do it yourself.
Heres what it looks like
http://www.eeshops.com/images/Wii-bluetooth-module-J27H002-for-Nintendo-Wii-console.jpg
Goodluck and I really hope I helped!
Apr 11, 2010 | Nintendo Wii Console
Nintendo wii remotes that do not respond at all.
hello,
i have looked around for you and i believe all you need to do is press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it.
and it should work like a charm to get you back to throwing some curve's in wii sports!!!!!
i hope i have helped and i hope it works!! let me know how it works
Jan 03, 2010 | Nintendo Wii Remote Controller
Sync remote with console
hello there if you remove you back from the controler there is a orange button under there next to the batterys at the bottom on the right side its small and round also open the front flap on the front of the wii there is a square red button next to the memory card reader once you have opend both controler and front on the wii with batterys in and the console on hit both buttons around the same time and hay presto one working controler with ur nintendo wii
Feb 03, 2009 | Nintendo Wii Console
Wii remotes not responding to Wii console
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 06, 2009 | Nintendo Wii Console
Need help programming wii console remote
take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
Dec 19, 2007 | Nintendo Wii Console
Nintendo wii controller
you need to sync the controller...
click here
http://wii.nintendo.co.uk/55.html
hope that works!!
Dec 09, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
