Question about Sony PlayStation 2 (PS2) Console
Playstation 2 problem
Hi, My playstation 2 console will not read any game disks, but did read and play a lens cleaning disk. Can you provide me with a solution for this problem?
  • Simdav Dec 27, 2007
    Thanks for that, but I have always had it horizontally and I did try it vertical. I also tried a brand new game and that did not work. Thanks anyway
    You P***k, I have had the console for about 8 years and just wandered if anyone knew how to fix it without chucking it and adding to the carbon footprint!!!!!!
Mine had stopped reading ps2 games but continued to read original ps games. I used some of that canned air and blew the dust off the lense. It's working fine now.
Posted on Dec 31, 2007
    Problem Solver:
  • 18 Answers
I would try cleaning your Playstation games, Check and make sure that the games your trying to play are not cracked in anyway. Also, if you have your system standing vertically lay it down horizontally. Many times after you've closed the disk in it lens to far away from the lens.
Posted on Dec 27, 2007
I sugeest you stop crying and go return the system back to the playstation compan dum a
SOURCE:
Disk read error
The reason your play station 2 keeps reading disc error is either because the lens is weak, dirty, or the disk is not compatible with the console.
You can try to use a lens cleaner to clean the lens or totally replace the lens with a new one.
You can also try other disc to see if its the same thing it will show.
Take care
Oct 09, 2010 | Sony PlayStation 2 (PS2) Console
PlayStation 2 (PS2) Console: not reading disk...
Playstation 2's are very sensitive to outside elements that get in it, such as dust or dirt, I suggest you clean your lens with some canned air, Personally I disassemble mine and clean every inch of mine using canned air, Q-tips, rubbing alcohol or purer, and WD-40 to lubericate the bearings and plays like I bought it yesterday. Hopefully these will answer your questions if your playstation 2 has never suffered damage by any blows or impacts.
May 05, 2010 | Sony PlayStation 2 (PS2) Console
My playstation 2 makes a weird clicky sound when I try to play some of my dvds or games and sometimes it comes up with disk error or unable to read disk and its a brand new disk
Your PS2 lens is displaced from its original position that is what scratching your Discs and makes weird noises too.There can possibly be another reason for them ,your PS2's reading lens is dirty and it is covered by a layer of dust that scratches your Discs and makes sounds too.
You should first clean the lens of your PS2 watch this video to know how to clean your PS2's lens:
Disk read errors are mainly due to dirty or worn out lens,so clean your PS2's lens to get rid of this problem and as for that sound that will get fixed by cleaning lens if still it makes that sound then you will have to take your PS2 to repairer to set the lens height.
Thank you!
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
My playstation wont read any of my gaming disks i
Have you tried a lens cleaner kit?
This is the CD-ROM with a small brush on it to clean your laser lens head.
This problem has happened to me in the past and this solved the problem.
It is a common problem for any lens reading console.
Regards
Aug 02, 2009 | Sony PlayStation 2 Slimline Console
My PS2 wont read any disk.
HI, the optics assembly has failed. the actual optical lens assembly will need to be replace in this case. you can try to clean the lens with a cleaning disk.. this may wake the laser. if the cleaning doesn't produce results, replacing the optical lens assembly will be the next move.
Jul 21, 2009 | Sony PlayStation 2 Slimline Console
Playstation 2 Disk read error.
try cleaning the disk with cleaner if you dont have cleaner use water
Jan 21, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2 slim
you might want to get a long q-tip and gently put alcohol on it and swap the lens.then have another tip ready to dry off. ps2 games are basiclly a dvd . and you can find info about a lawsuit that sony has against them for not being able to read dvd's.
Jul 19, 2008 | Sony PlayStation 2 (PS2) Console
Disk Reads Error problem and/or disk freezing
Hello, first step should be to clean the optical pick up unit. There is a special CD for cleaning of the optical unit (wet method). If this does not provide a solution please come back and advice. Best regards, Arpi
Aug 09, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
