Question about Sylvania 6413TC 13" TV
Sylvania 6427CTC TV problem
TV works fine - remote does not - therefore unable to use any DVD or VCR player etc.(need the input or game function on the remote )- I purchased a Phillips "big button" universal remote control from Walmart. I have put in every code they suggested and when this did not work - I surfed the web for additional codes eg. Funai
HELP - the TV is for my grandchildren for their movies and games
  • smontgom Jan 08, 2008
    same problem here. Is there a way to fix the remote feature on the tv?
  • 4 Answers
Uqgfqe.
Posted on Jul 23, 2008
HOW DO I DO CONNECTIONS OF INCOMING CABLE AND DIGITAL ADAPTER TO TV, VCR, AND DVD PLAYER?
Without seeing the exact connections for each device, i'm going to have to guess. But you should be able to connect your VCR to either your tv directly or to your DVD player. Remember you will need to use the "input" button on your TV or DVD player remote to switch from cable tv to your VCR and back.
May 02, 2014 | Emerson Televison & Video
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
Need code for universal remote for sylvania srd3900 dvdvcr
Check these codes:
0456 [0458 0227] [0458 0236]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Mar 29, 2012 | Sylvania SRD3900 DVD Player/VCR
I am trying to get a remote code for my slyvania 6719
I also can't find the remote for my Sylvania
TV/VCR/DVD combo...
Model number 6719DF. I don't normally use this tv
(it's an extra spare that I plug into our generator when
the power goes out... since our regular family TV is
quite big and set into the wall making it difficult to
track cords around, I drag this crappy Sylvania down
from our dining room to our family room) I did
happen to find an old Zenith universal remote that
does work with it in some ways (See directions
below). I can turn the TV on and off, set the channels,
language, clock.. etc through the Input select button
on the universal remote but can't set to "Game Mode"
after using connections with video/audio input cords
plugged into the front panel of the TV. So
Playstations, extra dvd players or vcr's, etc won't
work.
Switching from the VCR to DVD and vice versa does
require manually setting the tv itself (remote doesn't
work with that) but at least I can set sub titles, fast
forward through chapters on Dvd's and control the
volume, etc without having to constantly walk over to
the tv.
Programming the remote: I've noticed a lot of people
have tried using codes supplied by different universal
remote providers and couldn't find a code that
worked using their lists with this particular model...
there is a way that it can be done but it's a bit more
time consuming:
Many types of "universal" remotes give the option of
"scanning" the electronic device for a code if one is
not available or the one provided with lists does not
work... Every universal remote though needs certain
buttons pushed during the "scan" and they are all
different! Ha! So if you lost or misplaced the MANUAL
as well (like me!) you might need to do a search on a
manual for your particular universal remote, but I can
at least give you directions on programming a
"Zenith" Universal remote to "scan" for a Sylvania
TV/DVD/VCR combo model 6719DF:
Using the Zenith Universal Remote or any Universal Remote using it's "scan" method:
1: Shut off the TV
2. Press and hold "Code Search" on the remote until
the red LED
light lights up and stays lit.
3. Press the device button for the device (In my case,
for my crappy Sylvania combo, I pressed "TV".)
The LED light will blink once.
4. Scanning: Slowly press and release the "Power"
button on the remote, waiting a few seconds between
while watching the TV to turn on. It's very important
that you pause in between because if you do it too fast
and the TV turns on before you press the power
button again... you'll have to start all over. I've
learned that lesson.
It took 160 presses each time on that button to get the
correct code scanned! I had to do it over 3 times
before I stopped myself beforehand because I was
pressing it too quickly..
5. Right after the TV power turns on, press the "Mute"
button on the remote to set the code. It should work with few limitations (no "game" mode)
after that.
May 26, 2011 | Sylvania 6719DF 19" TV/VCR/DVD
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
How do we access the DVD player's menu without a remote?We were given a Sylvania DVL 100A but it has no remote, and I need to get to the menu and turn on the SDH (Subtitles for Deaf and Hard of Hearing)....
You could try purchasing a universal remote. Many of them can access even the most specific functions, although it might be labeled differently on the remote (so if you don't see it on the remote, just play around and it might really be there. I've had my input control for a TV actually turn out to be the TV/VCR button on my universal remote). Make sure it's a universal remote with DVD controls, otherwise it might not have that function at all.
Other than that, there's nothing else I can think of, since most DVD players don't have any menu button(s) on the unit itself.
Jun 02, 2010 | Sylvania DVL100A DVD Player
URC-4021B00 codes
http://www.oneforall.co.uk/us_US/support
May 21, 2009 | One For All URC-4021 Remote Control
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
I need a remote code
have the same problem. I have Chunghop Universal remote RM88E but unable to find code for ORBIT DVD player
Dec 24, 2007 | Sylvania (SRDD495) DVD Player/VCR
Sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Aug 13, 2007 | Sylvania 6427TE 27" TV
Sylvania 6413TC 13" TV Logo
191 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
