Question about Baumatic 23 in. BDW13 Built-in Dishwasher
E4 error message
My diswasher displays error message E4 -the drain pump has automatically cut in. The manual says to call an engineer, but as this was a result of a blocked filter rather than leak or repeating overflow, is there any way odf resetting the diswasher - the manual solutions for resetting with other problems don't work.
  • 2 more comments
  • jasper4000 Dec 27, 2007
    Try switching off at mains for 48 hours - it should reset
  • Anonymous Feb 12, 2008
    E4 error no apparent reason it isnt over filled & drains ok when switched on - how darn annoying no way of getting passed the E04 error
    ???Help
  • Anonymous Mar 14, 2014
    error code e4
    my new diswasher has stopped and is showng error e4 code
Take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Posted on Apr 05, 2008
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
Dishwasher was mid cycle and then displayed e4 error message. Manual says something about over-filling (water) but it is not clear how to rectify problem. Do you have suggestions for me please?
Check and make sure that dishwasher is draining all the way out. If not clean the sump inside under the spray arm and or the drain lines and back check valve.
Nov 30, 2010 | Dishwashers
Danby diswasher ddw1806bsl e4 code
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
Apr 07, 2010 | Danby DDW1806BSL Stainless Steel Built-in...
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
Problem with Candy CDI45, Error E4
The instruction manual defines E4 as "overfilled", a possible reason being too much inlet water. What helped with our machine - removed all dishes inside, then let the machine's pump run briefly to make sure as much water was drained from the system as possible. I then unplugged the device, placed a large towel on the floor around its base, and tilted the machine front-ward, until all water had run out. Lifted the machine back upright, plugged it in, switched on - and voilà! it's working as I speak.
Feb 28, 2008 | Dishwashers
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
593 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
