Your symptom sounds like a damaged convergence IC.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some insturctions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values. There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need. Their site is http://www.andrewselectronics.com/welcome.aspx And their phone number is a 24-Hour Order Desk: (800) 274-4666 I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue. If you need further assistance please comment to this post and I will try to help you further. asnowman
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic PT-43LC14 43 in.
Panasonic PT-43LC14 43 in. Rear Projection HDTV Television
My set, Panasonic HDTV Projection Monitor PT-53Wx42,was working fine while my daughter was playing...
(More)
My set, Panasonic HDTV Projection Monitor PT-53Wx42,was working fine while my daughter was playing Rock Band then 1) the screen went green, then red, then black (off), and then 2) when trying to turn it back on (after unplugging for 10 minutes) the red "ON" indicator light will flash red three times at 1 second intervals, remain off for 5 seconds, and then repeat the sequence. Any suggestions?
panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after...
(More)
panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
