Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
PROBLEM E6 smeg df614ss
Problem E6 keeps coming on, will not wash as it cannot drain, i have made several attempts to clear the filter and base bit with boiled water, pipe cleaners ......but i cannot clear the problem, the dishwasher is only 4 mths old
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: Al.
Posted on Feb 10, 2007
  • 944 Answers
SOURCE: Error message on Smeg dishwasher
Sorry couldn't find the info online - try these guys, they are the official smeg service agentsm and they have a live chat feature too -perhaps you get lucky and they will tell you the problem; Hope this helps - if you get no luck from them then please post again :)
Posted on Apr 23, 2007
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
  • 833 Answers
riff...not sure what the bits are...first, they may be food crumbs or the like. Dishwashers have macerators to grind up food particles but they have no really good way to get rid of them in the wash cycle. Scrape plates of any solids before loading them. If the material is shaped like water droplets, you may have hard water stains. Use Jet Dri or a cleaning product which claims to help and use the amount specified. Your water temp may be should be 125F or better. If you can run the hot tap and put your hand under isn't hot enough. You can also use the heated water setting to deal with this.
Posted on Dec 11, 2007
  • 247 Answers
The second problem is almost certainly a symptom of the first - leaking water is reaching some of the electrical terminals and shorting them to earth.
First thing to do is to make sure the strainer in the bottom of the cabinet is clear - if it's really badly choked, you can brew up quite a spectacular flood.
After that, best I can suggest is to move the machine onto a piece of dry carpet, run it for a short while and see whereabouts the carpet gets wet first. Use this to guide your subsequent leak-hunting.
If there's any hint that the leak is from the front of the machine, check the seal between the lower edge of the door and the bottom of the washing chamber. On some machines, this gets covered with a thick layer of hardened grease (which is fine, until bits of the grease start to break off). If this is your problem, scrape the remaining gunge off, give the metal surface a good clean,and expect the last vestiges of the leak to cure over the next couple of washes as the seal recovers its proper shape.
Next thing to look for is the device which senses when the machine is full enough (and tells it to stop filling). Let the machine get to the stage when it is leaking nicely, then turn it off, open the door, and see if the cabinet has filled to overflowing. If it has, then drain it, then unplug the machine and take the back cover off. Look for a thin hose coming out the bottom of the washing chamber and running up to a small unit mounted on the case some way up with a pair of wires going to it. Check this hose for cuts, splits and blockage.
If the leak is coming from further back, then you are going to need to look inside to see how much of the inside of it is wet. Use this to guide you to where you need to do a more detailed inspection.
Check all the nearby hoses, looking for splits - especially where they push onto fittings, cuts (especially anywhere they're pulled over sharp edges) and just generally to see if they've pulled off completely.
Next, check any plastic fittings in the area to make sure they haven't cracked, and look to see if there's any evidence of water seeping out of the joints between the different fittings (in case you've blown an O ring, rotted a gasket away, or just had some screw work loose)
Posted on Apr 13, 2008
0 characters
1 Points
I have a LG Dishwasher, Model LDF7551ST invert-er direct drive, and it's been getting this (OE) error, it worked fine for about a yeaR
Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Jan 04, 2016 | LG Dishwashers
Bosch SilencePlus shows E:15, Aquastop, and Watertap!
Hi Greg,
E15 on the Bosch units indicated the base switch is activated. There is a safety switch which will activate the drain pump to avoid the base overflowing. Basically you either have a leak or possibly rodents living in the base of your dishwasher.
Easy way to check is first make sure no water is inside the washing area or sump (where the filter is). You will have a dribble there which the drain pump won't pump out but make sure it is mostly empty. The dishwasher always drains at the beginning of a cycle if you need to manually activate this, just turn you tap off so it doesn't try to fill. unplug your dishwasher then pull the machine out and place some old towels along the base and tip if forward. If water run out from the base then you got a leak.
If you are a bit handy then you can take either the front kick plate and cover off or a side panel to look in the base. The float switch is a polystyrene disc which raises and hits a micro switch when the base fills up.
Common place for these to leak is the sump, wash motor or water path / distribution unit. Look for chalky white residue around the seals. Depending on the age of your unit some parts are more serviceable than others. Bosch are pretty good with spare parts so you should be able to source most items you need.
If you are not handy or technical and are concerned about taking on this work, call in a technician. Remember disconnect power before attempting any work. please.
I hope this helps.
Apr 13, 2014 | Bosch Dishwashers
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
Our fisher and paykel dishdrawer won't wash. It comes up with F1 and flashing light on control panel.
the dynamo dishwashing stuff has caused foaming which reached the base of the dishdrawer unit causing the flood switch to trip. This gives F1 error.
Not sure how much foaming has occured.
Best to turn off power and take power cable out from socket. then empty the drawer using towels. pull out the bottom drawer and wait a day or so to let the foam disappear from the bottom of dishwasher (under the bottom drawer). Connect the power and see if F1 had gone. If not, you need more work. Post a comment based on the above suggestion and I will guide you further if required. Always use Finish dishwasher power only (recommended quantity) as the drawers are small and don't need much detergent.
Dec 27, 2012 | Fisher Paykel Dishwashers
Smeg e01 error
E1 error code is an antiflood error code.
Water will be in the base of the washer due to a leak. So what you need to do is pull the washer out and tip it 45 degs backwards and the water will drain out from the base. so you may need a towel for that part.
Once the water is out the antiflood switch will reset itself and the washer should start to work again from there.
Then just keep an eye on it and see if you can locate the leak if there is 1.
Read more: We have a Smeg WMF 16 AX washing machine with E 01 fault code. - JustAnswer
Nov 24, 2012 | Dishwashers
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Smeg dishwasher Beeps when trying to drain...seems to wash ok but
Check your air gap at the sink for internal obstructions (take it aoart and clean it) Also check the dishwasher drain outlet into the garbage disposal (if you have one) They tend to clog up inside the garbage disposal. You may have to pull the hose off that connects to the garbage disposal to clean the hole out.
Feb 28, 2010 | Smeg 24 in. DWI612 Built-in Dishwasher
Grinding sound SA8605x
Sounds like machine may have activated flood switch- this makes the dishwasher drain continously, which results in a grinding noise once the machine has no more water to pump out.
The flood switch is located in the base of machine- you need to remove bottom front panel to acces (disconnect from power first!!).
Once panel is removed, check:
-Is there water in the base? If so, machine has had a leak- clear water, restart, and locate + repair leak.
-If no water in base, it may have air lock in pressure tube. There is a small clear tube that goes to round flood switch on base of machine- remove tube and blow thru. Reassemble and test machine.
Only attempt if you a confident DIYer- if in doubt, call an expert (you can sometimes make an easy repair an expensive one)
Aug 10, 2009 | Smeg CSU2001 Built-in Dishwasher
Smeg dishwasher EN50242
have a Smeg STX-45 dishwasher. After washing the utensils, machine is not able to drain the water. Can you please tell me what could be the problem. Is there any switch I need to press for the same or something else. I have used the machine for the first time.
Oct 12, 2007 | Dishwashers
Will not drain and shows E6 error code
I had this problem and eventually found a small piece of mussel shell in the bottom part of the machine, it seems they are very sensitive to the tiniest fragment of debris.
Sep 24, 2006 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Level 1 Expert
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
