Minolta EP4000/5000 CS/PRO Copier
Problem for Minolta EP4000/5000 CS/PRO Copier
Error code c0070
By baiju_rawthe on Oct 14, 2009
error code c0070
Clarification Request
Posted by gbsoffice on Oct 14, 2009
Hi, and welcome, I need some more info, did you by chance just add new toner?
Solution #1
posted on Oct 15, 2009
Not Rated)
Cogz
Rank: Guru  Minolta Expert
Rating: 86%, 459 votes
A error code C070 has to do with the toner hopper motor. Did you just put a new toner in. If so, carefully remove it and turn the copier off & close the front door & turn it back "ON" and let the copier come to "Ready". Once it is ready, reistall the toner bottle and close the door and see what happens. If it is not cleared you most likely have a problem with the "HP" flag for the toner bottle. Good Luck..
Was this helpful?
Yes
No
Popular Solutions for Minolta EP4000/5000 CS/PRO
Questions and Unsolved Problems for Minolta EP4000/5000 CS/PRO
Do you recommend Minolta EP4000/5000 CS/PRO Copier?
Answer
Answer
Shredder repair technician in the city of Palmdale or Lancaster CA
Answer
haveing problem with ben q projector- when you turn it on the ben q logo comes on then the picture... (More)
Answer
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message.... (More)
Answer
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Minolta EP4000/5000 CS/PRO...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
