Sansa e260 connected player to computer , have disk in drive , installed software off disk ( coverter ) but comuter does not accept player. it finds new hardware starts to wizards it . starts searching then stops saying error in installation invalid data. i've change usb settings on player no change i've downloaded new firmware no good player screen says connected but computer says not.
player shows connected on the screen but computer does not see it as a drive or that it is connected?player shows connected on the screen but computer does not see it as a drive or that it is connected?
I have the exact same problem...when i first plugged it in it tried to install some software but then said it could not find it and now the installation screen no longer eve n comes up.. on the mp3 player screen it says connected but it does not show up in my computer as a drive or anywhere else.I have the exact same problem...when i first plugged it in it tried to install some software but then said it could not find it and now the installation screen no longer eve n comes up.. on the mp3 player screen it says connected but it does not show up in my computer as a drive or anywhere else.
You can't post conmments that contain an email address.
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link
After installation connect your sansa...... Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard)....
USB
mode located on the sansa if asked to change to MSC goto menu press
enter scroll to settings press enter scroll to usb mode press enter
scroll to msc press enter press menu.....Connect should auto start sansa
software.....
Sansa software/driver
Updates firmware follow instructions
Downloads manual
Downloads converter
Sansa
Not Recognized: Try connecting it to the back of your computer or another computer the back straight
to the motherboard this should be USB 2.0 and see if it will recognize
it as sansa or Drive/removable drive. if it does then download the sansa
update software
and install it. Make sure you disconnect the sansa and connect it when
asked. This will update your sansas firmware and add the Usb Mode. Try
to connect it to your computer at home it should recognize.... link for
update software
download to a flash drive much easier. Make sure USB mode is MSC Recovery Mode may also allow your computer to recognize the sansa lock
your sansa hold in the rec key on the left at the same time push the
menu/power button this will take you to recovery mode then connect to
the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier I used my friends labtop it worked USB 2.0
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier ..Make sure sansa usb mode is in msc
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
Turn on the e200 v2
Put the device in Hold (move Hold button until orange is showing)
Press and hold the Left Button
Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
Wait for the e200 drive(s) to show up
Follow instructions below and drag files to the e200 drive
