Zanussi washing mashine
Hi, i have a zanussi washing mashine ZWF1220W (1200 essential)
lately when it gets to the point of loading water for rince programme,the pressure simes to be very high and most af the water goes aout on the floor from the soap drawer,never happened before and nothing has ghanged,mashine position or water pression from the main.
What can i do or what can the problem be?
Thank you
Roberto Verde
0131 2298362
  • 1 more comment
  • robertone Dec 30, 2007
    Thank you. I appreciate very much your prompt response.
    i have ordered a replacement part for my washing mashine and waiting to get it,but I am sure that it will solve the problem.
    I will let you know once the job will be compleated.
    Thank you again
  • robertone Jan 03, 2008
    Hi dear,
    I have now reiceved the new part,fitted and unfortunatly the problem still the same(water caming out from the soap dispenser when mashine loading water for rince(with any program)
    Any more suggestions or I should buy a new mashine even if is only under 3 years old?
    Thank you
    R
  • Anonymous Mar 27, 2014
    wher can i find the specs for a zanussi z16 washing mashine
    President:
  • 1,294 Answers
Plug off the wall. Open up behind, you will find a thin tube, maybe tranparent or black coming down from the control panel to the exit area (pump area) of your machine. Carefully disconnet this from above and blow into it, it should be free, if not clear it, if kinked or broken replace.
If this does not work, its your solenoid valve at the entrance point of your machine, top right, where the water is received. Just change this. If all works fine rate me please.
Posted on Dec 27, 2007
Zanussi 1200 essential washing machine, cleaned out filter now will not fill with water
Go back into the machine and check for a disconnected wire cause by cleaning out the filter. Oh and did you remember to turn the water faucet back to the on position? It helps to plug the machine in to the A/C outlet, too. Keep an eye attuned to a safety switch on the access panel as well. It may have an alignment or broken plastic fastening/ mounting design.
Feb 08, 2014 | Zanussi F1045W Front Load Washer
Zanussi zwf1220w
Pressure system fault probably
Jun 17, 2013 | Washing Machines
Zanussi 1200 6kg, not spinning or taking in water ?
Try unplugging the unit for 30 mins. then run it again.
Nov 21, 2012 | Washing Machines
Hello there, I've buy zanussi fae 825 v washing mashine and now faced with problem. Mashine fill with water, then drain it off, then indicator of end of washing flashes three times, then goes out and...
First: make rapid reading of alarms
How: the appliance is in normal operating mode (e.g. while the washing programme is in operation) than:
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
The alarm is displayed by a repeated flashing sequence of the two LEDs: 1. END OF CYCLE indicator = indicates the first digit of the
alarm code (family)
2. START/PAUSE ? indicates the second digit of the alarm
code (number within the family).
After reading alarm code look down=
Could be:
E33 - Incongruence between contact closure of antiboiling and 1st
level of pressure switch.
Remedy: Pressure switch faulty; Current leakage from heating
element to ground; Heating element; Wiring faulty; Circuit
board faulty.
E35 - Water overflow.
Remedy: Water fill solenoid faulty; Leaks from pressure
switch hydraulic circuit; Pressure switch faulty; Wiring
faulty;Circuit board faulty
E36 , E37, E39 - Circuit board faulty
Dado
Jan 24, 2018 | Zanussi Washing Machines
Missing user manual for Zanussi Essential 1200
I have downloaded a manual for the item
May 17, 2009 | Washing Machines
I have a 6 year old Zanussi model FJS 1025 W.
hi
it looks like the electronic programmer it is not being read past that point.
suggestion get the programmer dynastic tested, some programmers can be reprogrammed or replace with anew one
Dec 21, 2017 | Zanussi FS1055W Front Load Washer
Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Zanussi washing mashine zwf 1220 w water overflou
Why not just reduce the pressure at the inlet wall faucet. But dont reduce it too much or your clothes wont rinse well.............
Jan 04, 2008 | Washing Machines
Washing Machines Logo
350 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
