Question about Refrigerators
Leaking Whirlpool refrigerator
What causes refrigerator to leak inside the refrigerator underneath the vegetable crisper drawer so it has to be wiped out every morning?
  • 15 more comments
  • Anonymous Jan 01, 2008
    My Whirlpool refrigerator is leaking water inside,under the drawers and the top shelf.Help !! I can't find were the water is coming from. Vickie
  • Anonymous Jan 06, 2008
    freezing freezer and bottom is warm
  • Anonymous Jan 16, 2008
    I have a problem with water collecting under the veg. bins and running out on the floor.  I have to clean it up about every 3-4 days.  This is a full size refrigerator without a freezer.   HELP!!!!!!!
  • Anonymous Apr 26, 2008
    I have the same issue. Though mine also results in sheets of ice under the crisper as well. Has anyone answered this issue yet?
  • Jbaugous1 May 04, 2008
    My Whirlpool refrigerator is not working and is leaking water, but the freezer is working just fine, is this a cheap fix?
  • sam440 May 05, 2008
    my whirlpool refridgerator is leaking inside underneath the bootom drawers and on the top shelf inoticed the water is dripping down from some vent or something....please help. whirlpool is standard with frost free freezer on top.
  • Growler48 May 12, 2008
    I have a Sears Kenmore that is somehow leaking water to the bottom of the fridge, below the crisper drawers. The ice maker and fridge seem to be working fine and I can't find any condensation trails on the inside to see where it might be coming from. Any help would be appreciated. Thanks.
  • jsterling May 17, 2008
    My Whirlpool refrigerator also leaks water. It pools up under the vegetable bins and then leaks out onto the floor. There seems to be a vent on the back (inside) right above the bins where it might be coming from. Does this require a repairman to fix?
  • vslg1 May 18, 2008
    Same problem
  • Anonymous May 27, 2008
    leaking into and under vegetable bins in the fridge
  • Anonymous May 28, 2008
    Yes,I have the same problem with my refrig#ET18PMXSWoo model#E82034727.What can I do to solve this ? You didn't say anything to the complaints here.I don't want to pay $75 for a guy just to come to my house!!! Please advise & I hope you don't tell me to junk it. abook6@yahoo.com
  • cottondog May 28, 2008
    Yes I have the same problem
  • Anonymous Jun 29, 2008
    The whirlpool sucks!! I had the guy come out, from Sears- and I paid him for nothing but to say that all of the church's in the area have the same fridge so it looks fine!! Contacting whirlpool is impossible! Both Sears and Whirlpool will not get my business again.
  • Anonymous Jul 09, 2008
    water in bottom crisper shelves
  • slex44 Feb 19, 2009
    that makes a lot of sense. I have an 11 year old kenmore fridge that is dripping water on the top shelf of my fridge section. i have been using a rubbermaid plastic container to collect the water temporary. i will try to remove the plastic tray from he freezer and see what the problem is. i am in the same boat. i don't want to replace a refrigerator for a minor problem since most refrigerators out there are very expensive these days.
  • Anonymous Mar 22, 2009
    Solution #2 corrected my problem
  • pcdarcan May 11, 2010
    Solution number 2 (above) appears to have worked on our Whirlpool refrig. The drain was frozen solid (not allowing water to drain down to the catch pan). We followed the suggestions correct this problem. Thank you.
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Posted on Nov 12, 2008
  • jefftheweeke Mar 13, 2011
    Solution # 2 resolved the issue for our Whirlpool fridge. God bless!
I had a problem with water accumulating on the first shelf and and underneath the drawers in the bottom of the refrigerator. I traced it back to the overflow cup that is located inside the refrigerator in the middle of the top. NOT inside the freezer, but rather in the the refrigerator portion.
Unload the top shelf and place some paper towels near the back of the shelf to catch about a 1/2 cup of water. Gently grab the tab on the overflow cup and slide it towards you. I am willing to bet there is a large plug of mold inside the pipe on the cup that has been blocking the drainage.
Now is a good time to clean up the water under the drawers in the bottom of the fridge and while you are at it, clean the shelves.
Posted on Jun 01, 2008
Thank You #2 - I have had water in my veg bins for months. I thin it is fixed now. I pulled off the covers from the bottom and the back wall of the freezer..GROSS. Now I have to put it all back together again. Thanks again...what a great site.
Posted on Aug 15, 2009
Great Job solution #2! This totally fixed the problem. We have dealt with bowls in our fridge for over two months!!! We have a whirlpool and you couldn't even see the drip pan until we de-thawed all of the ice under the freezer flow. Thanks so much you saved us buying a new refrigerator : )
Posted on May 29, 2009
I had a problem with water accumulating underneath the drawers in the bottom of the refrigerator also. After reading several of the solutions to this problem here I checked the overflow cup inside the fridge by pulling it out, but the tube attached to it was not blocked, so I pulled the fridge out from the wall, unbolted the overflow tube from the back, behind the evaporator coil, and pulled it out. The tube is about 3 1/2" long and extends from the outside back of the fridge thru the outer wall, thru insulation, and thru inner wall where the small overflow cup tube then plugs into this larger tube.
I found that this tube was blocked by mold right where it makes a 90 degree turn and where the diameter decreases. I cleaned it out and put it all back together again by reinserting the large dia. drain tube from the back to where it would just appear inside the fridge, bolting it back into place, and then reattaching the overflow cup to this tube by sliding the tube attached to the overflow cup into it from inside the fridge.
The water seems to be draining fine from the freezer compartment, so I believe that this was my only blockage.
Posted on Apr 15, 2010
This is due to the freezer drain freezing up and it has no where to drain but in the bottom of the fridge. I have to turn mine off every few months and let it thaw out and then it will work for a while. It is a Whirlpool and they need to come up with a fix.
Posted on May 25, 2008
FRIDGE IS LEAKING LOTS OF WATER UNDER THE CRISPERS
Good Afternoon Friend,
I understand your Frigidaire refrigerator, model# GLHT184TJ, is leaking water underneath the crispers. First, make sure the door is closed as well as you are not opening it frequently or for long periods of time. Secondly, make sure all foods and containers are covered. Lastly, make sure that all vegetables have been dried, if you have washed them, before storing them in the crisper drawers. All of the above can cause moisture inside your refrigerator, which can accumulate at the bottom of your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLHT184TJ Top Freezer...
Water build up
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Refrigerators Logo
11,248 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
