Question about Toshiba 40H80 40" Rear Projection Television
40wh08b convergence problem
Hi experts,
had tv since oct 2000 ......couple of months ago on switch on had the odd grouping of what appeared to be flyback lines but only in small area of screen [not all the way accross].....this problem did not show all the time.intermitant.....ABOUT 4 days ago this problem disappeared and now the tv has a bent picture DOWN at bottom left...bent UP at top right of picture........this means that the RED and BLUE are out of syncronisation by as much as 1.5 inches ie showing a blue and red picture outline......the centre of pic and top left and bottom right still appear okay.....normal convergence adjustment will not sort this........shame to get rid of...tubes /guns still good and strong.......pic still very good ...........HELPPPPPPPPPP
bernard
  • 5 more comments
  • bbd750 Dec 27, 2007
    hi,
    bernard here.thanks for info...ps live in uk england......been looking at other peoples similar problems.....ic numbers different ie stk392-150
    stk392-160
    stk392-110t
    and your part stk394-160e
    or hitachi pt cz 01341
    silly question are they all correct
    is stk394 correct or should it be stk392
    i can solder.....but havent taken on this task before ....any more advice/tips to ensure smooth installation.....is there any special setups to do after installation which would require advanced menu access...finally TV SAFETY --only thing i understand is earth myself and apply limited heat to ic.....any further tips..
    thanks bernard
  • bbd750 Dec 28, 2007
    hi,
    took back off tv ......had very close look at ic's.....soldering looks superb.....18 solder points per ic.......GULP
    number is STK392-110 on both
    tv model is for european market 40wh08b this is the 100 htz model with built in 5.1 dolby digital system ....thanks for your patience...couldn't access site earlier ,just kept taking me to a main page on how to become an expert and earn money!!!!
    looking forward to your reply .
    bernard
    hi,
    looks like you recommend ic's 160e...but if i have trouble obtaining these could i use 110/110t or even 150 as long as good make..original 110's have been in for 7 yrs
    okay i found ic,s but possibly not that good to identify what you say is B+ feed resistors .....any help identifing them ie size shape etc and how many am i looking for
    ps
    had good look at all components both sides of ic's nothing looks burnt or discoloured......but still don't know if i was looking at B+feed resistors...are they on ic side or heat sink side....2 x sets of 6 green components behind heat sink 3 x small 3 x large [2 sets] and 2 x black cylinder components [total 4]either side of ic/heat sink..........starting to show my ignorance now......HELP
    ps its 3.28 in the afternoon here do you go to sleep!!!!!!bernard
    hi,
    me again.....your last comemt 10 am friday implies i have been looking at resistors.......ive had a test run and had full panel out of set after removing all wire connectors and re installed unit to check still works [albeit with convergence fault]
    finally any more tips see my 1st reply /coment ....do i have to use any special/advanced menues to set up after installation of ic's or just normal convergence menu....ALSO is there a stk392-110E available as an alternative to the 110T
    thanks for your help
    bernard
    signing off as its nearly 12 at night here
    ps petrol is equivalent to $9.40 a gallon here ---any suggestions on FIXING THIS !!!!!
  • bbd750 Dec 29, 2007
    hi,appreciate all your help..........final query...looks like i've seen pictures of a bonding paste between ic's and heatsink to transfer the heat..........do you use this..what is it ...what is product called..and would it be something to obtain via my ic supplier......
    ps was i looking at the resistors!!!!!!!!!!!
    bernard
    hi,
    final final query
    i noticed other sites state stk394-250 is the direct replacement for the stk392-110
    do you have any thoughts/comments
    also just to reiterate and go back to first posting
    this tv is and will converge on most areas of the screen
    it is only the top right quarter and bottom left quarter that shows this problem...in those two areas on convergence menu [which puts 9 numbered markers and a large cross in centre of screen to assist manual alignment] i can adjust blue and red left and right but not up and down.........can i take it that this is in line with ic failure and that only random areas of screen can/will be affected by this ic failure.....
    any more info on the resistor numbers and ohms of each resistor as i may choose to replace at time of ic installation...
    i appreciate your patience in answering all these on going reply/comments.....not all us limeys are the same
    bernard
    thanks for the reply...but could you possibly look at the rest of my last posting
    ie about resistors and convergence as you seemed to focus onto only first third of this comment/reply.......
    sorry to pester you again but if you are unable or can't answer these points then just say .
    thanking you in advance and asking you to remember that your the expert and what might seem simple to you may need a little more info /help with as we say [putting the meat on the bones] for us thickies
    Genius:
  • 1,694 Answers
Convergence IC's need replacement = STK392-110 original #...
Use name brand Toshiba, NAP, or upgrade to STK394-160E
Hitachi part # CZ 01341...no cheap generics..they won't hold up..
Chassis pull and some precision soldering will be needed....let me know if you need further info...........................T.
Posted on Dec 27, 2007
  • 6 more comments
  • Vista Electronics Dec 27, 2007
    Bernard,
    Thank you for your ? 's and comments...all info is helpful.....
    1) Remove back of set and look at large heatsinks with IC's
    on them.....what is the number on the originals ?
    2) Verify model # off back of your tele......
    Caution: Before ordering parts,we can discuss which IC's are
    "best" and what will waste your time and labor........T.
  • Vista Electronics Dec 28, 2007
    Thank you for your reply !
    1) Toshiba STK392-110 subs to STK392-110T ( ok to use )
    2)Hitachi brand has an upgrade ...over the last couple of years ..
    STK392-110 sub STK392-150 sub STK394-160E ( upgrade )
    Therefore, the best, but not cheapest is....
    STK392-110 original sub to STK-394-160E = Hitachi part #
    CZ 01341....I use several pairs of these per week.......
    3)Next,you should examine carefully the B+ feed resistors next
    to the IC's for burn or over-heating....usually visible....T.
    No rest for the weary !
    Sounds like resistors are ok.........use quality IC's of your choice
    and go to work !...............................T. I0:00 AM Friday
  • Vista Electronics Dec 29, 2007
    No special prep.......STK392-110 is generic description = each
    MFR has their own Part #....Toshiba,Philips,Hitachi.....I only
    recommend Original Equipment Manufacturer ( OEM ) parts..
    anything else ...you are on your own...
    PS. 100 pounds or 100 dollars....which one has more value ?
    Your choice is...........??............T.
    I use heatsink compound on each of the STK's I replace..T.
    Final,final,final comment !!!
    Remember : STK392-110 is the common description of the
    most common convergence IC used in most such repairs today.
    Best replacement is HITACHI PART # CZ 01341.......
    STK392-250 is a common IC.....If you use it as a sub for -110,
    Who says it is a quality sub ? What Manufacturer ? What is their PART # ?? One more example = TOSHIBA STK392-110 subs to STK392-110T = TOSHIBA PART # 23135090
  • Vista Electronics Dec 30, 2007
    Replace the IC's and your convergence problems should be
    solved................I don't usually change any resistors unless
    they are visibly damaged.....If I need to know the value I look
    with a magnifier at the resistor, as my eyes aren't what they used to be...or
    I look in the service literature if I have it....or I call the parts
    supply armed with the board location and they assist me...or
    I research on the internet............................................but,
    many times,there is no resistor damage...........................T.
    Bernard,
    If you don't feel qualified to DIY ( do-it-yourself), you might
    want to hire a tech......at least you have the info to ask the
    proper questions ......Terry.
  • Vista Electronics Dec 31, 2007
    Bernard,
    Thank you for the Fixya ! rating.........let me know the final outcome.........Terry.
KP-51WS500 it started a couple months ago the
Hi, that is look like ,,you have defective convergence module if it is a dlp it is probly the light bulb,
hope that will help you to find a good tech
to fix it.
have a nice day
May 05, 2010 | Sony KP-51WS500 51" Rear Projection...
HAVE A JVC AV-56WP30 REAR PROJECTION TV THAT THE PICTURE APPEARS IN A BOWED SHAPE. THIS TV WAS JUST REPAIRED FOR THIS PROBLEM ONE WEEK AGO AND IN 100 MILE DRIVE TO PUT IN APARTMENT IT IS AGAIN NOT WORKING....
The convergence is dead,Must replaced Convergence ICs and resistors.Tell the shop to repair it again.They probally didn't replaced the ICs or resistors.This problems can't come back about a week,at 6 months i can understand.
Jan 11, 2010 | Televison & Video
My TN55X81 is showing the same problem.
Replace the IC's with STK 392-110T.
Toshiba has a Service Bulletin on this problem.
Aug 01, 2009 | Toshiba TN61X81 61" Rear Projection...
Wt-46809 has convergance issues
Replacing the Convergence IC's should do the trick. But it is not a easy repair do to the disassembly requierments. I would recommend calling Mitsubishi at 18003322119 to get a local service facility to come out and give you a estimate to repair.
Jun 21, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Toshiba 43HX70 convergence problem
One or both of the STK convergence chips have probably failed.
I can give you guidance on this if you are confident to do the repair. I had the same problem with my Tosh 40WH08B and after replacing these chips it works like new.
May 21, 2009 | Toshiba Televison & Video
Toshiba Rear Projection Tv 40WH08B
If the convergence on one or more color does not align using the convergence setup procedure, that means that one or more convergence ICs must be replaced, that is the reason why you get bad picture.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 10, 2009 | Toshiba 57H81 57" Rear Projection...
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Color appears to change every 10-20 seconds
This is either a problem in the convergence regulator circuit or the convergence module
Apr 09, 2008 | Samsung HCN5527W 55" Rear Projection...
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
152 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
