Question about Ovens
No indication on display module - apparant loss of power
After a temporary power failure to the house the oven display did not re illuminate and the electrical oven did not work in any mode.. Basic checks on circuit breakers and fuses did not identify the problem. Gas hobb works normally.
  • jppower Dec 27, 2007
    Whirlpool Model AKZ185/1X, Type FCEM6
  • baerbel Jun 14, 2008
    I had a power brownout and then a failure. The oven does not work (upper or lower). Is there a reset? There is no power cord as the istallation instructions indicate that the ovens are directly wired to a junction box. Any clues?
Did you check the power cord.
Connection(s) could have been fried during power surge.
Posted on Dec 27, 2007
    Problem Solver:
  • 8 Answers
The answer is the following. We had a temporary blackout and after this "STOP" appeared with no other signs of life and none of the buttons responding. The function knob on the left had side should be turned to "0" and after this is done, push the center button - I did this by a complete fluke and everything came to life again. After being a photocopier service engineer - let me tell you that this is probably a deliberate piece of electronic engineering to earn Whirlpools service dept. a bit of extra money.
Posted on Mar 01, 2009
I have a Whirlpool Super Capacity 465 and am having issues with the following. Sometimes while baking, the oven turns off and the power to the appliance stays on, sometimes everything shuts off and PF
PF stands for power failure you are loosing incoming power power check the terminal block the control will do goofey thing with loss of voltage rule of thumb no more than a 10% voltage loss 108VAC minuim
Aug 04, 2014 | Whirlpool Ovens
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
Hi, I have a wo570xd double oven and the controller is playing up, ihave had F& P send me a new controller (572942p), this controller did not work so contacted them again and they have sent out a new...
fisher & paykel oven model WO570XD seems to be no power from source to the wall oven however range top works fine. Power light on switch to oven is illuminated indicating there is power however there is no lighting on digital display unit. Any help appreciated
May 31, 2011 | Fisher and Paykel Ovens
I have a Dacor ECS130 and when we turn it off the F1 code comes up and it beeps forever. i tried uplugging the membrane switch from the control/clock module (with the power off) and there is no F1...
Hi
Thanks for using FixYa. Error F1 in your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Ovens
Display has very light illumination and does not display temperature or other settings. All functions seem to work but functions are not shown on display including temperature, Bake/Broil cycle, etc. Time...
This is a failure in the electronic range (or oven control) ERC or EOC. You can replace it with a new one, or have it repaired.
- www.fixyourboard.com
Jul 26, 2009 | Ovens
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
The light and temperature display are very dim and hard to see.
Steve Patterson
303-256-8494
Nov 23, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
Steve Patterson
303-256-8494
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
267 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
