Question about Beko Dishwashers
Beko dishwasher problems
Been using the dishwasher over xmas as normal,went to put it on today and all the lioghts are on as normal but got nothing doesn't try to click or water come in. checked the waste pipe,drainage,connections,put salt and rinse aid in now i'm lost help!!! the dishwasher is a beko dwd5410w
SOURCE: Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
Posted on Jan 22, 2008
  • 108 Answers
SOURCE: dihwasher not working
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermitten fault. Hotpoint replaced the unit for a mimum charge. Callout + 40
Posted on Feb 27, 2008
SOURCE: Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Posted on Apr 08, 2010
  • 8619 Answers
SOURCE: inlet/drain, salt and rinse aid light flashing
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do rate the solution if the issue is resolved or else revert for further assistance.
Posted on Jun 06, 2010
SOURCE: Dishwasher leaves white film on
If your dishes or plastic dishes appear with a white filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
I have dishawasher BEKO and I can't close it. It keeps opening. It seems nothing is stucked in the "locker" system.
good to know the problem is fixed. In future please feel free to report any other problem with this appliance or any other appliance problem on this fixya site. Please make sure you have the correct make and model number listed when you enter the fixya site. This helps identify the solution better.
Apr 22, 2014 | Beko Dishwashers
Beko dishwasher
Perhaps you pinched the water line when you moved it back in.
Jan 24, 2014 | Dishwashers
Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
May 09, 2010 | Dishwashers
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Brand new dishwasher, doesn't drain water and will not work now!
try this site Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Dishwasher not working
dishwasher dwd 3410 w,it runs normal to the end but doesnt drain the water
Mar 25, 2008 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
111 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
