Question about Daewoo L17D (Metallic) 17 in. Flat Panel LCD Monitor
DAEWOO L17D Monitor Drivers
I need drivers for this monitor. Where can i find them?
  • lesieur Dec 29, 2007
    RECOGNIZED AS PNP?
2 Suggested Answers
  • 4 Answers
SOURCE: Daewoo L700C 17 in. Flat Panel LCD Monitor
www.dtforum.net search here
Posted on Feb 10, 2009
Hp vista and monitor hp2509 was working fine. i uninstalled monitor driver but now computer starts fine but monitor goes blank
Monitor drivers are built into windows OS, you can't uninstall the driver unless you went to devise MGR, monitor, and opened proprieties and hit uninstall, and even then when you restart windows, it will auto reinstall the hardware. So what you're saying does not make sense.
If you reboot and noting, try a system restore, if you have a windows disk, then run repair. But like I said, you don't install monitor drivers, DVD rom drivers, these are generic drivers that are made into windows. If you think a monitor has a driver that needs installing, explain how people install windows if they couldn't see the monitor.
Only onboard video and graph cards need drivers to run the video at its intended resolution, but it does not need a driver for the monitor, it's built into windows.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
I need ibm thinkvision lcd 19 driver
Hi Aslam
LCD MONITOR DRIVERS
You don't say what problems you are having with the monitor that you hoped drivers would help to resolve. Add a comment or a clarification request, if necessary, with more information about the actual problem might give you ideas for alternative repair strategies with a higher prospect of success than looking for Drivers.
Most display problems are rooted in either a faulty or incompatible graphics card, corrupt or incorrect graphics drivers, a damaged monitor cable or bent monitor cable connector pins.
A Monitor by itself controls only a very limited set of display properties, such as frame margin position, brightness, colour saturation and colour contrast.
Almost without exception, there are no monitors that require drivers to function with an Operating System. Virtually every monitor works with the Plug and Play .inf drivers built into Operating Systems. The graphics drivers are a totally separate issue from the .inf monitor drivers.
Accessing almost every driver download website that claims to have drivers available for download for specific models of monitor, will result, despite however optimistic the stages at the beginning of the download process might seem, in arriving at the actual driver download page only to find that no drivers are ever available after all. While driver download pages for some monitors might exist, no actual drivers are ever available to download from them.
If there is no physical defect with the button controls on the monitor, you should test the monitor at different graphics resolutions, different refresh rates (both under Graphics card or graphics chip settings), test a different monitor cable and then test a different monitor. These are the only practical options available.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 22, 2011 | IBM ThinkVision L190 19" LCD Monitor
I need a new driver for my soyo monitor
Your soyo monitor doesn't require a driver. Make sure you download and install the latest driver for your video card and during the install of that, your monitor should have its drivers installed as well. At that point you'll be able to use your monitor properly. There isn't any drivers available on the net that I could find. Only other option is if your monitor came with a cd, that might have drivers on it.
Jan 14, 2010 | Soyo DYLM24D6 LCD Monitor
I lost my drivers
You probably do not need them. At least not for today's operating systems. Maybe you can get one from the manufacturer's website.
Jan 05, 2010 | Daewoo 719B 17" CRT Monitor
LG MONITOR 15'' DRIVERS FOR LINUX RHEL FOR LINUX RHEL AS 4 UPDAT
You do not need driver for the monitors otherwise I will be real busy downloading the drivers for 2-300 monitors I repair every year, you do need driver for the video card in your PC. The LCD monitor needs to be fed with 60Hz refesh rate set by your PC and the native resolution it needs.
Jan 05, 2010 | LG L1915S 19" LCD Monitor
Need Graphics Drivers for Samtron SC-423ps model
For the monitor? In 10 years I've never needed drivers for a monitor, I think you need drivers for your display adapter, check the maker of your computer's website / support - download section for drivers.
Mar 31, 2009 | SAMTRON 55V 15" CRT Monitor
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
Monitor resolution can't be changed
some 15" monitors do not support 1024 by 768, check your monitor specifications if it does. google on the net with the exact monitor model no. and see if it supports.
Sep 28, 2007 | LG Flatron 995FT 19" CRT Monitor
Daewoo L17D (Metallic) 17 in. Flat Panel LCD Monitor Logo
120 people viewed this question
Top Daewoo Computers & Internet Experts
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
