In this case, we need to reset the computer back to factory settings.
here we go...this process will cause data loss. 1. Remove non-essential peripherals like a) Scanner b) Printer c) Modem or Network cables d) Personal Digital Assistant (PDA) e) USB flash drive or other external Hard Drive f) Any other external devices (e.g., USB-attached devices) g) Remove the computer from the docking station, if you are using one. 2. Turn on the computer. 3. When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time. NOTE: Some systems like Inspiron Mini 9 (910) do not support System Restore as they do not have <F11> nor any substitute. 4. In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>. 5. When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear: The system recovery process was successful. 6. Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dell Latitude D600 PC Notebook
My D600 does not respond when it is plugged in and charging. If I unplug it, it works fine. It...
(More)
My D600 does not respond when it is plugged in and charging. If I unplug it, it works fine. It charges completly. Any ideas?
my pavilion dv2000 will not boot up past start up screen. can i download a boot disk or recovery...
(More)
my pavilion dv2000 will not boot up past start up screen. can i download a boot disk or recovery disk for this laptop
my dog chewed through the power cord on my dell D600 lap top and killed it, i bought a new power...
(More)
my dog chewed through the power cord on my dell D600 lap top and killed it, i bought a new power supply but it still wont start up, thinking that it may have shorted some thing out i put in a new power board but it still wont start any ideas/
