Nintendo Wii Console Logo
Posted on Dec 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wii image gone
Wii was working fine for few days and I was seeing what difference switching settings would have.( silly me !)
I switched from 50 hz to 60 hz and screen then lost the image ( just "whiteish" screen) Can hear that its on and when moving remote can tell its "on" behind the white screen but can't see menu to change it back to 50hz.( if thats the problem)
Tried resetting and get a momentary flash of the start up image before whitescreen appears again. Can anyone help ?
Anonymous
Level 2:
  • Expert 167 Answers
  • Posted on Jan 25, 2008
Anonymous
Expert
Level 2:
Answers
167
Questions
0
Helped
96375
Points
194
Try connecting to a tv that supports 60hz. But you should read up on this stuff before you do anything like that again. Understand , understand? alright! but do not do anything like that again!
My celcus tv wont go back to wide screen
Replace the display panel at-once. Do not switch ON the set until you have replaced it. Risk of fire!!!
Need to transform 120v power to 240v
Bad news:
UK has 50 Hz electricity, and appliances are rated for local power..
Any appliance made for US market is rated 60 Hz.
50 Hz and 60 Hz electricity are different.
Look at label on your mixer, and then look at labels on local appliances. You will see 50 cycles or 60 cycles. Rarely appliances are labeled 50-60 cycles.
http://www.worldstandards.eu/electricity.htm#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html#Hz
http://waterheatertimer.org/What-is-3-phase-electric.html#120-240
Hz Hertz or cycles or frequency is number of rotations the electric generator turns per second.
Some appliances are rated 50-60 cycles and will work worldwide.
However most appliances are rated 50 or rated 60 but not both.
60 cycle motor will not perform as expected when connected to 50 cycles. And might overheat.
Generally, most motors can be converted to different voltages by taking motor to motor shop (if you can find one these day)
However electronic controls cannot be converted between 120V and 230V, nor will 50 Hz electronics work with 60 Hz power
Sorry Sue.
Buy another mixer.
Business will benefit from surge of consumer buying.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
How do I program the H5CX ASN timer to turn on 5 mins and off 25 mins in an endless cycle. I don't understand the term Output Mode so from that point the instructions become meaningless.
Omron:
https://www.ia.omron.com/support/
http://waterheatertimer.org/pdf/h5cx_sell-sheet-wiring.pdf
I believe you have 230Volt 50 Hz electric power.
Omron is rated 50-60 hz
US timers are rated 60 Hz.
Maximum load on Omron timer is 5amp at 230 volt
Timer should be connected to 2-pole contactor (relay) instead of directly connected to pump.
http://waterheatertimer.org/images/contactor-drawing.gif
Does Amazon sell percentage cycle timer in your country?
A cycle timer makes one full revolution each hour, or 4-hours, or 12 hours. Then percentage is set for 8% for 1 hour cycle.
Contact Intermatic and ask if they have 50 cycle percentage cycle timer, or ordinary cycle timer in 50 Hz.
I have Distorted Picure Quility with any game i Play?
check that both tv and wii are on same Hz settings(50 or 60)
New Nintendo Wii
check you've got it on the right PAL/NTSC setting.It's very likely the 50/60hz setting. 480i running at 60hz is NTSC resolution although the PAL Wii of course uses the PAL signal. The TV probably tries to interpret the signal as a real NTSC signal because it's 480i 60hz and thus can't handle the colors. There has got to be an option to switch between NTSC and PAL.
Are you using the same SCART socket that you use for your other consoles or a different one? My SCART3 input on my Panasonic telly has two different modes - one which displays in colour, and one which displays in a sort of grainy black n' white. There is a purpose to it but I can't remember what it is. :-)
Anyway, you switch between the two by pushing the AV button and then hitting the colour button which corresponds to SCART3 a few times 'til you reach the correct setting.
It probably isn't that, but... y'know. Sanity check.
3answers
Panasonic pt50lc13
That is weired... Silly question, but did you try to plug the wii in a different 'input terminal'??
2answers
EasyCam Pro (HO98064)
Try a different driver if your not happy, remove cam and uninstall driver again through add/remove programmes. When you re connect use a different USB port if available. http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+gjlg2202ff442544 Sometimes the frequency needs to be set at 50HZ, the same as an Eye toy when it's used as a web cam, as the drivers are usually multi country.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
