Does not get power from feed linechecked power line and all is good. Cleaned and drained entire unit. could solenoid be bad? Unit was performing well before it neded de-frosting
The icemaker turns on fine, water runs through the system however the pan will not drain. I have...
(More)
The icemaker turns on fine, water runs through the system however the pan will not drain. I have confirmed no clogs. System eventually shuts off, displays P1 problem code.
the ice maker is running and the water is alson runing, however it doesn't get cold enough to make...
(More)
THE ICE MAKER IS RUNNING AND THE WATER IS ALSON RUNING, HOWEVER IT DOESN'T GET COLD ENOUGH TO MAKE ICE.
