Question about Nikon COOLPIX S5 Digital Camera
Monitor remains black
Hi, my monitor remains black when I turn the camera on, despite the fact that the shutter opens normally
  • Anonymous Mar 26, 2008
    the monitor remains black when i turn it on even though all the other settings work normally.
  • Anonymous Apr 02, 2008
    me too! everything else (preview,flash, sound) works perfectly (even when choosing cyan/red color)..but the screen/picture remains black..help!
    Guru:
  • 1,894 Answers
Press display button once or twice..
Posted on Dec 27, 2007
My Camera Canon Powershot S1IS has lights but the shutter will not open. I can't see anything looking through the view finder or through the LCD monitor. CF card ishas few pictures and placed correct
Make sure it is not in bulb or B for shutter speed. That will keep the shutter open and make everything black. In fact, just set different shutter speed and try. Recycle power of course. Can you see into the lens from the front, with flashlight if needed? And of course the final basic check, is the battery fully charged?
Jan 20, 2015 | Canon Cameras
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
When i turn my camera on the screen is black. when i take a picture the screen remains black and when i press review of the picture i took that is black as well. is that a back light problem or something...
Try downloading the picture to your computer to see if it is also black. If so, then yes it may be a shutter issue. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 21, 2010 | Kodak EasyShare C330 Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 12, 2009 | Canon Cameras
When camera is turned on the monitor is black, takes black pictures
hi..
A stuck shutter is common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter.....
thank u
Jul 10, 2009 | Olympus Stylus 850SW Digital Camera
Panasonic SD H80 Lens cover
Make sure gas valve is turned on. Make sure spark plug is not soaked. If has has a primer, only prime it about 3 times. No more than 5
Jul 03, 2009 | Panasonic SDR-H40 HDD Camcorder
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
My lcd screen is black
hi there guys, if the screen is black and the camera takes black pictures, then you should look if you are getting a on screen display on camera mode. if you are then i would say one of two things, either the shutter is not opening or the ccd( electronic imaging device) is not functioning. to check the shutter you should look into the lenses centre part and check for movement from the shutter to see if it is opening.
Jun 06, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic DMC-LZ2 Camera
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens. Then open the camera and see if the ccd flex is correctly plugged in.
Jan 13, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Nikon COOLPIX S5 Digital Camera Logo
125 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
