Fuji FinePix S5000 Digital Camera
Problem for Fuji FinePix S5000 Digital Camera
I am getting images in the LCD screen that are
By smoulton74 on Oct 14, 2009
i am getting images in the LCD screen that are posterized with greenish tint - the images are the same when downloaded ?
Comments:
Oct 14, 2009
- thhanks for your expertise! i have found the problem to be "on & off"... i used it friday with no problems... saturday morning it worked fine, but then saturday afternoon the problem appeared... then on sunday morning it worked for about 10 shots...then problem re-appeared. it worked fine monday morning for a short time but the problem re-appeared again. I checked it last nite (tues) and the screen was a greenish tint, but image did not seem to be as distorted as it had been previously (is this an indication of anything beyond what you mentioned previously?)
Best Solution
posted on Oct 14, 2009
Very Helpful)
StephanSA
Rank: Guru  Cameras & Camcorders  Expert
Rating: 93%, 184 votes
Firstly , let me state that because I cannot see the camera or open it , my advice is extremely limited to my past experiences.
I suspect that the CCD/CMOS (the chip that physically captures light and creates the digital image) has broken.
If this is the case , a repair would cost approximately $100. This is the most common problem for a camera that takes distorted images but where the menu display functions and old photo's display normally.
Check to see if the video function works normally.If this does not work, it supports the idea that the chip has gone. Also see if photo's uploaded and again downloaded to and from the card looks normal. If these photo's are normal , its almost for sure you ccd.
I would take it in to a repair center for an evaluation , but would not have it repaired if the CCD has to be replaced as a new or refurbished camera would cost only slightly more.
Please feel free to contact me if you need further information
Kind regards
Stephan
Comments:
Oct 14, 2009
- Well , the erratic nature of the problem would suggest that it is not so much to do with the CCD sensor as with the cables connecting it. This cable (a elongated data cable like a IDE cable) is glued onto the ccd and as a camera ages , this normally malleable glue gets hard and could eventually crack and break.
I suspect that this is what has happened and thus , I would suggest you take it in for repair/evaluation as this is definitely beyond the scope of a DIY fix. In warranty they should do it for free , out of warranty , your looking at about ($40-$70) depending on the dealer.
Kind Regards
Stephan
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" your advise is greatly appreciated!... ...i will let you know how it works out gratefully, s moulton " - smoulton74
Popular Solutions for Fuji FinePix S5000 Digital
Questions and Unsolved Problems for Fuji FinePix S5000 Digital
Do you recommend Fuji FinePix S5000 Digital Camera?
Answer
Answer
when in photo mode it changes to preview mode...without changing switch
Answer
Hi when i turn the camera on it starts up comes up with the finepix on the screen then just switches... (More)
Answer
My battery door will not latch shut. The hold tabs are broken off. Is this fixable? Fuji Finepix... (More)
Answer
When turning on the camera to take a picture, many times there are horizontal lines in the view... (More)
Answer
hello all of a sudden my camera will not take anything but black pics. the lens seems not to be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fuji FinePix S5000 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
