Question about Sharp AL 1631 Copier
D-Copia 150 d with display showing
Hi colleagues:
Somebody knows this machine? we have a new one that shows " d " and doesn't work.
thanks in advance and best regards.
  • 2 more comments
  • José Antonio González
    es, just a " d ", and machine rests inoperative.
    Best regards and H.N. year
    yes. Just a " d ", and machine rests inoperative.
    Thanks an Best Regards
    Yes. Just a " d " and machine rests inoperative, also keyboard.
    thanks and Best regards
    thanks tryit
    i've already know this procedure, but the keyboard is also blocked.
    thanks, i'll try to fix, changing main board.
    thanks and b.r.
    Jantonio
    President:
  • 2,072 Answers
Just a D?
No number after the "d" or when you press zero does a number come up?
Posted on Jan 02, 2008
  • 1 more comment
  • Rick Kasper Jan 03, 2008
    Here is the procedure for clearing fault codes. I just wanted to be sure you were not having any secondary codes occuring.
    WorkCentre XD100 Digital Copier - Laser Printer Online Support
    Solution Perform a Fault Reset 14
    Make Printable
    Email this page
    Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
    1. Find the pink Clear button on the Control Panel of the WorkCentre.
    2. Find the button below the word Auto.
    3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
      NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
    4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
    5. Press the green [Start] button.
    6. Press the pink [Clear] button two times.
    7. The WorkCentre should now warm up and come to ready.
    8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
    This is the same procedure for Sharp and Xerox products. Sharp makes both.
    I am curious what fixes that. Please let me know. This is one of those that is driving me crazy ..
Hi, I'm a bit new at using the net and posting for
No take the top off and the clip or a giant jubilee will be on the back of the rubber inside the machine not accessable from the door front .
Jan 30, 2012 | Whirlpool Washing Machines
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Display is showing code SC 542.
the error is for a heating eror in the fuser either toner build up on the thermistor or the thermofuse has blown if you have the machine turned on press the yellow clear button and then input 107 and then hold dowwn the stop button.. turn machine off and wait a few seconds then turn back on.. this should clear it if it was just a fluctuaction in temps.. if that doesnt work take fuser out and check the condition of the temp sensors and do reset again.. if the code stays on you will have to go into the service mode.. acccessed the same way as reset but you need to enter the copier sp and then go to 5.Mode and look for 810 this is the sc reset execute turn off and then on >>>>Hope this helps A
Jul 30, 2009 | Ricoh Aficio 1035 Copier
Hidden files and folder are not displayed
you have virus in your system use antivirus to remove the virus it is the virus blocks you from accessing the folder ........
Feb 04, 2009 | Compaq Computers & Internet
Wireless internet connectivity problem
On an unsecured access point (not WEP or WPA) it should work.
Try here for advice http://forum.eeeuser.com/
Presumably you don't need to set a proxy in Mozilla?
Aug 06, 2008 | ASUS Eee 4G Notebook
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Sharp AL 1631 Copier Logo
83 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
